coq-club - Re: [Coq-Club] Beginner Question
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Beginner Question
  • Date: Sat, 08 Nov 2014 11:43:52 -0500
On 11/08/2014 10:53 AM,
saulo2 AT gmail.com
wrote:
Hi,
I am trying to port a defitional interpreter for a small DSL from Standard ML
to Coq. The first problem I am facing is how to define self referential values
in Coq. Thats what I am trying to do:
Require Import String.
Open Scope string_scope.
Inductive OBJECT : Type := Object : CLASS -> list (string * OBJECT) -> OBJECT
with CLASS : Type := Class : list (string * CLASS) -> CLASS.
Definition MediaType := Class nil.
Print MediaType.
Definition File := Class (cons ("mediaType", MediaType) nil).
Print File.
Definition User := Class (cons ("picture", File) nil).
Print User.
Definition Message := Class (cons ("sender", User) (
cons ("recipients", User) (
cons ("replies", Message) nil
Print Message.
but the Coq complier complains "Error: The reference Message was not found in
the current environment."
What you were trying to do with Message is define a self-referential (cyclic) data object, which Coq won't let you do (unless you use codata - but you probably don't want that).
You should probably put a level of indirection between a class's structural definition and its use. I would suggest defining class tags first, then class structures that reference those tags. Then define a mapping from class tags to class structures.
This might look something like:
Inductive CLASSTAG : Type := ClassTag : string -> CLASSTAG.
with CLASS : Type := Class : list (string * CLASSTAG) -> CLASS.
Definition Message := Class (cons ("sender", ClassTag "User") (
cons ("recipients", ClassTag "User") (
cons ("replies", ClassTag "Message") nil
Definition tag_to_class : CLASSTAG -> CLASS := ...
-- Jonathan
