- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Beginner Question
- Date: Sat, 08 Nov 2014 14:27:07 -0500
On 11/08/2014 12:53 PM, Saulo Araujo wrote:
Thanks a lot Jonathan! Your suggestion works like a charm! Could you help
me with some other doubts?
1) I tried to use the notations [], [x], [x;y] and x :: y but had no luck.
What kind of preamble (Require Import, Open Scope, etc.) do I have to use
to be able to use these notations?
Require Import List.
Import ListNotations.
2) I tried to define a function that receives a list of classes and a class
name and returns an option containing the class (if there is a class with
the same name) like this:
Definition getClass classes name := List.find
fun class =>
match class with
| Class name' attributes => name = name'
end
) classes.
but the compiler complains "The term "name = name'" has type "Prop" while
it is expected to have type
"bool". I did some research and I believe I understood why. My next
attempt was:
Definition compareStrings x y := if prefix x y then prefix y x else false.
fun class =>
match class with
| Class name' attributes => compareStrings name name'
end
) classes.
and the compiler is happy about it. My doubt is: is there a more idiomatic
way to compare strings in Coq?
The term [name = name'] in Coq is not a comparison at all. It's a type (actually, a Prop, which is a kind of Type). That's probably rather confusing for programmers, but it's easy to get used to. It's the type of proofs that name is the same as name'.
A better definition of compareStrings would be:
Definition compareStrings x y := if string_dec x y then true else false.
3) In SML is possible to do pattern matching directly in the function
parameters and val assignments. There are useful when the only thing you
want is to extract the values inside another value. Is this possible in
Coq? I tried this
fun (Class name' attributes) => compareStrings name name'
) classes.
The closest is to use a destructuring let:
Definition getClass classes name := List.find (fun c := let (name', _) := c in compareStrings name name').
Alternatively, you could define a projection function on a class to get its name. Or, use Record to define a class, which would automatically give you the projection functions.
4) Is it possible to define local functions in Coq? I am looking for
something like let clauses in SML.
Yes - let can do that as well. See ref manual section 1.2.12.
-- Jonathan
- [Coq-Club] Beginner Question, saulo2, 11/08/2014
- Re: [Coq-Club] Beginner Question, Jonathan, 11/08/2014
- Re: [Coq-Club] Beginner Question, Saulo Araujo, 11/08/2014
- Re: [Coq-Club] Beginner Question, Saulo Araujo, 11/09/2014
- Re: [Coq-Club] Beginner Question, Jonathan, 11/09/2014
- Re: [Coq-Club] Beginner Question, Pierre Casteran, 11/09/2014
