- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Beginner Question
- Date: Sat, 8 Nov 2014 23:43:17 -0300
Nice to hear that Jonathan!
Thanks again!
Saulo
On Sat, Nov 8, 2014 at 11:37 PM, Jonathan <jonikelee AT gmail.com> wrote:
On 11/08/2014 08:51 PM, Saulo Araujo wrote:
Hi Jonathan,
I am sending the whole file but, since changing from Some value to Some v
did the tricky, don't bother trying to understand what is happening unless
you are curious ;)
This file is accepted by the trunk version of Coq I'm using without any complaints. So, whatever was causing that mysterious error was eventually fixed.
-- Jonathan
Require Import String.
Open Scope string_scope.
Require Import List.
Import ListNotations.
Definition compareStrings x y :=
if string_dec x y then true else false.
Inductive CLASS : Type :=
Class : string -> list (string * string) -> CLASS.
Definition getClass classes id :=
List.find
(fun class => let 'Class id' _ := class in compareStrings id' id)
classes.
Inductive OBJECT : Type :=
Object : string -> string -> list (string * list string) -> OBJECT.
Definition getObject objects id :=
List.find
(fun object => let 'Object id' _ _ := object in compareStrings id' id)
objects.
Definition getAttribute attributes name :=
List.find
(fun attribute : string * list string =>
let (name', _) := attribute in compareStrings name' name)
attributes.
Definition getValue object name :=
let 'Object _ _ attributes := object in
match getAttribute attributes name with
| Some attribute => let (_, value) := attribute in Some value
| None => None
end.
Fixpoint getValues objects name :=
match objects with
| object :: objects' =>
match getValue object name with
| Some value =>
match getValues objects' name with
| Some value' => Some (List.app value value')
| None => None
end
| None => None
end
| [] => Some []
end.
Thanks again!
Saulo
On Sat, Nov 8, 2014 at 9:34 PM, Jonathan <jonikelee AT gmail.com> wrote:
On 11/08/2014 06:52 PM, Saulo Araujo wrote:
One more doubt. In the code below, the Coq compiler complains about theI would have to see the whole file prior to that definition to tell you
lines with Some value. It says "The constructor Some expects 1 argument.".
When I change from Some value to Some v everything works fine. Is there
something special about "Some value"?
match objects with
| Some value =>
| None => None
end
| None => None
end
| [] => Some []
end.
what is going wrong. The use of "value" in a binding position, such as in
that match statement, shouldn't be a problem - but it might be the case
that Coq isn't inferring the types the way you expect, depending on what
comes before getValues.
-- Jonathan
- [Coq-Club] Beginner Question, saulo2, 11/08/2014
- Re: [Coq-Club] Beginner Question, Jonathan, 11/08/2014
- Re: [Coq-Club] Beginner Question, Saulo Araujo, 11/08/2014
- Re: [Coq-Club] Beginner Question, Saulo Araujo, 11/09/2014
- Re: [Coq-Club] Beginner Question, Jonathan, 11/09/2014
- Re: [Coq-Club] Beginner Question, Pierre Casteran, 11/09/2014
