- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Beginner question about pattern matching in Ltac, using "context"
- Date: Fri, 21 Nov 2014 20:37:56 +0200
I tried to use "context" in tactics. Here's example that I tried (unsuccesfully). Somehow "context" doesn't work like I had imagined although in very many cases it's okay.
Require Import Classical_Prop Setoid.
Theorem T (P: Prop): (False -> P) <-> True.
tauto. Qed.
Theorem T0: forall n, (False -> exists m, m = S n).
match goal with
| [ |- context[False -> ?P] ] => setoid_rewrite T
| _ => idtac
end.
setoid_rewrite T. auto.
Qed.
How can I fix it? (I read about it in adam.chlipala.net/cpdt/html/Match.html)Require Import Classical_Prop Setoid.
tauto. Qed.
match goal with
| _ => idtac
end.
Qed.
- [Coq-Club] Beginner question about pattern matching in Ltac, using "context", Ilmārs Cīrulis, 11/21/2014
- Re: [Coq-Club] Beginner question about pattern matching in Ltac, using "context", Jason Gross, 11/21/2014
- Re: [Coq-Club] Beginner question about pattern matching in Ltac, using "context", Ilmārs Cīrulis, 11/25/2014
- Re: [Coq-Club] Beginner question about pattern matching in Ltac, using "context", Jason Gross, 11/25/2014
