Re: [Coq-Club] Beginner question about pattern matching in Ltac, using "context"
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Beginner question about pattern matching in Ltac, using "context"
- Date: Tue, 25 Nov 2014 18:37:56 +0200
Thanks! (And sorry for late answer.)
In this case simple "setoid_rewrite" was all I needed, nothing more.If I want to match (bind) open terms, I must start writing advanced tactics, don't I?
On Fri, Nov 21, 2014 at 9:49 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Ltac variables cannot bind open terms. Because your [P] would mention [n], Ltac does not match. If you do "context[False -> _]", that should work fine. Alternatively, remove the reference to [n] from your theorem statement, so it's just [nat -> False -> exists m, m = m] or something.On Fri Nov 21 2014 at 1:38:23 PM Ilmārs Cīrulis <ilmars.cirulis AT gmail.com> wrote:I tried to use "context" in tactics. Here's example that I tried (unsuccesfully). Somehow "context" doesn't work like I had imagined although in very many cases it's okay.How can I fix it? (I read about it in adam.chlipala.net/cpdt/html/Match.html)
Require Import Classical_Prop Setoid.
Theorem T (P: Prop): (False -> P) <-> True.
tauto. Qed.
Theorem T0: forall n, (False -> exists m, m = S n).
match goal with
| [ |- context[False -> ?P] ] => setoid_rewrite T
| _ => idtac
end.
setoid_rewrite T. auto.
Qed.
- [Coq-Club] Beginner question about pattern matching in Ltac, using "context", Ilmārs Cīrulis, 11/21/2014
- Re: [Coq-Club] Beginner question about pattern matching in Ltac, using "context", Jason Gross, 11/21/2014
- Re: [Coq-Club] Beginner question about pattern matching in Ltac, using "context", Ilmārs Cīrulis, 11/25/2014
- Re: [Coq-Club] Beginner question about pattern matching in Ltac, using "context", Jason Gross, 11/25/2014
