coq-club - Re: [Coq-Club] Beginner question about pattern matching in Ltac, using "context"
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Beginner question about pattern matching in Ltac, using "context"
  • Date: Tue, 25 Nov 2014 20:02:06 +0000
Dealing with open terms in Ltac is a persistent problem without a good solution, at the moment.  There are various ways of "recursing under binders", which is a workaround, by uncurrying, using typeclasses, or using tactics in terms in trunk.  (See, e.g, this and this.)
-Jason
On Tue Nov 25 2014 at 11:38:24 AM Ilmārs Cīrulis <ilmars.cirulis AT gmail.com> wrote:
Thanks! (And sorry for late answer.)
In this case simple "setoid_rewrite" was all I needed, nothing more.
If I want to match (bind) open terms, I must start writing advanced tactics, don't I?
On Fri, Nov 21, 2014 at 9:49 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Ltac variables cannot bind open terms.  Because your [P] would mention [n], Ltac does not match.  If you do "context[False -> _]", that should work fine.  Alternatively, remove the reference to [n] from your theorem statement, so it's just [nat -> False -> exists m, m = m] or something.
On Fri Nov 21 2014 at 1:38:23 PM Ilmārs Cīrulis <ilmars.cirulis AT gmail.com> wrote:
I tried to use "context" in tactics. Here's example that I tried (unsuccesfully). Somehow "context" doesn't work like I had imagined although in very many cases it's okay.
Require Import Classical_Prop Setoid.
Theorem T (P: Prop): (False -> P) <-> True.
 tauto. Qed.
Theorem T0: forall n, (False -> exists m, m = S n).
 match goal with
 | [ |- context[False -> ?P] ] => setoid_rewrite T
 | _ => idtac
 end.
 setoid_rewrite T. auto.
Qed.
How can I fix it? (I read about it in adam.chlipala.net/cpdt/html/Match.html)
