coq-club - Re: [Coq-Club] difficulty computing with integers in Ltac
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] difficulty computing with integers in Ltac
  • Date: Mon, 1 Dec 2014 18:12:06 -0500
You can do something silly like:
Tactic Notation "mydo'" int_or_var(x) tactic3(tac) := do x tac.
Tactic Notation "mydo''" constr(x) tactic3(tac) :=
  idtac;
  match x with
    | 0 => mydo' 0 tac
    | 1 => mydo' 1 tac
    | 2 => mydo' 2 tac
    | 3 => mydo' 3 tac
    | 4 => mydo' 4 tac
    | _ => fail 1 "number" x "too big"
  end.
Goal True.
  let N := eval compute in (1 + 2) in mydo'' N idtac 0.
(note that mydo' will give the same error message as "do", so it's probably also an int_or_var)
Alternatively, you can write an ocaml plugin to convert a constr to an int_or_var.
As to your question...maybe ltac variables or nat-interpretations are duck-typed, and so it's whatever you want it to be?
On Mon, Dec 1, 2014 at 4:22 PM, Jonathan <jonikelee AT gmail.com> wrote:
The following works:
Goal True.
let N := 3 in do N idtac 0.
Abort.
It produces 3 lines of "0".
So, why doesn't the following work?:
Goal True.
let N := eval compute in (1 + 2) in do N idtac 0.
Abort.
It produces the error: "Error: Ltac variable N is bound to a term which cannot be coerced to an integer.", with CoqIDE underlining the N in "do N idtac 0" as the source of the error.
How does one compute with integers in Ltac?
-- Jonathan
