coq-club - Re: [Coq-Club] difficulty computing with integers in Ltac
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] difficulty computing with integers in Ltac
  • Date: Tue, 02 Dec 2014 17:14:31 -0500
On 12/02/2014 10:08 AM, Frédéric Besson wrote:
Hi,
What about redefining a do like tactic ?
Ltac mydo x tac :=
match x with
| O => idtac
| S ?n => tac ; (mydo n tac)
end.
Goal True.
let N := eval compute in (1 + 2) in
let tac := idtac 0 in
mydo N tac.
Abort.
Best,
Frédéric
Amusingly, I was trying to use "do N ..." to avoid doing recursion in a case where I can calculate the number of iterations of a tactic I need.
So, my options appear to be:
1. write a plugin
2. try ssreflect
3. just do everything in Ltac via recursion
I've looked through the existing plugins and tactics, but it isn't obvious how to write a tactic that would convert from a numeric Gallina term into an Ltac number (ocaml integer?).
I will look at ssreflect - provided I can get one built and working for the trunk version of Coq.
In the meantime, just stick to recursion and avoid math in Ltac.
-- Jonathan
On 1 déc. 2014, at 22:22, Jonathan
<jonikelee AT gmail.com>
wrote:
The following works:
Goal True.
let N := 3 in do N idtac 0.
Abort.
It produces 3 lines of "0".
So, why doesn't the following work?:
Goal True.
let N := eval compute in (1 + 2) in do N idtac 0.
Abort.
It produces the error: "Error: Ltac variable N is bound to a term which cannot be coerced to
an integer.", with CoqIDE underlining the N in "do N idtac 0" as the source of the
error.
How does one compute with integers in Ltac?
-- Jonathan
