- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] difficulty computing with integers in Ltac
- Date: Tue, 02 Dec 2014 15:48:27 -0500
On 12/02/2014 05:28 AM, Georges Gonthier wrote:
If you really need this particular feature, you might want to consider the
Ssreflect plugin. Ssreflect tactics generally accept Coq integers along Caml
ones; in particular it is possible to compute iteration counts (as in do
N!tactic), occurrence selectors (set x := {+N}y), and subgoal selectors
(tac1; first N [tacN]).
-- Georges
I will try ssreflect. I am using the trunk version of Coq, so I note that the latest ssreflect sources are at: https://gforge.inria.fr/scm/viewvc.php/trunk/Saclay/Ssreflect/?root=coq-contribs. However - how is this downloaded? It doesn't work to git clone that address, or use it as an svn source repository.
- -Jonathan
- [Coq-Club] difficulty computing with integers in Ltac, Jonathan, 12/01/2014
- Re: [Coq-Club] difficulty computing with integers in Ltac, Cedric Auger, 12/02/2014
- Re: [Coq-Club] difficulty computing with integers in Ltac, Jason Gross, 12/02/2014
- Re: [Coq-Club] difficulty computing with integers in Ltac, Jonathan, 12/02/2014
- RE: [Coq-Club] difficulty computing with integers in Ltac, Georges Gonthier, 12/02/2014
- Re: [Coq-Club] difficulty computing with integers in Ltac, Hugo Herbelin, 12/03/2014
- Re: [Coq-Club] difficulty computing with integers in Ltac, Pierre-Marie Pédrot, 12/02/2014
- Re: [Coq-Club] difficulty computing with integers in Ltac, Gregory Malecha, 12/02/2014
- Re: [Coq-Club] difficulty computing with integers in Ltac, Frédéric Besson, 12/02/2014
