coq-club - [Coq-Club] Problem using heterogeneous lists for PHOAS
  • From: Murali Vijayaraghavan <vmurali AT csail.mit.edu>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Problem using heterogeneous lists for PHOAS
  • Date: Mon, 15 Dec 2014 00:47:12 -0500
Hi all,
I am a novice in using Coq, so I apologize in advance if the answer to
my question is too trivial or has been answered before (I just got to
know about this mailing list recently).
So, I am trying to adopt the PHOAS method
(http://adam.chlipala.net/papers/PhoasICFP08/PhoasICFP08.pdf) to
define a language.
I have a kind definition as follows (containing booleans and
C-structure-like objects):
Inductive Kind: Set :=
| Bool: Kind
| Struct: list (string * Kind) -> Kind.
I use heterogeneous lists whose definition is:
Section ilist.
Variable A : Type. (* The indexing type. *)
Variable B : A -> Type. (* The type of indexed elements. *)
Inductive ilist : list A -> Type :=
| icons : forall a As, B a -> ilist As -> ilist (a :: As)
| inil : ilist nil.
End ilist.
Now, I am trying to convert an element of the Kind into a Coq-native
type (like bool, or a heterogeneous list). I need heterogeneous lists
because a structure can contain other structures as in its elements.
In order to do this, I tried writing the following function [type]:
Fixpoint type (k: Kind): Type :=
match k with
| Bool => bool
| Struct attrs => ilist (fun a => snd a)
(map (fun a => (fst a, type (snd a))) attrs)
end.
This gives me Universe-inconsistency error. From my naive
understanding of Coq-universes, this error seems reasonable, since I
am trying to create a type which is quantified by elements, and these
elements can in turn contain the same type. But I am not sure if this
explanation is correct.
I tried another variant of the same function:
match k with
| Bool => bool
| Struct attrs => ilist (fun a => type (snd a)) attrs
end.
This gives me the recursive call error: [Recursive call to type has
principal argument equal to "snd a" instead of "attrs"]. My
understanding of this error is that Coq is not able to figure out the
decreasing argument of type, since I am applying it on some argument,
instead of on [attrs] directly.
This brings to my question: is there any way to write what I wanted
to, which is, convert values of my [Kind] into Coq-native types. I am
open to using some other [Type] instead of [ilist], if that can solve
my problem.
Thanks
Murali
