- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Problem using heterogeneous lists for PHOAS
- Date: Mon, 15 Dec 2014 11:14:52 +0000
- Accept-language: de-DE, en-US
Dear Murali,
I am also a beginner, so I might be wrong in what I say, but let me comment
on your problem.
First I don't think you can make a heterogenous list and then use this list
as an element type for the list. This should results in Universe errors, as
you alreay observed. But since a list of lists is more or less equivalent to
a tree, you can use a tree like data structure to describe your type.
Second it is a bit tricky to do structural recursion on your Kind type,
because you need to recurse over the Struct and the lists. I couldn't even
get this to work with mutual recursion, but with so called internal recursion
(see
http://www.di.ens.fr/~zappa/teaching/coq/ecole11/summer/lectures/lec9.pdf) it
works as below. Here I used simpel pairs to construct the type. You might
want to use something more eloborate to make the structure clearer, but as I
said before, I think it needs to be a tree like structure, not a list like
structure. It should e.g. be possible to keep the record filed names in the
types.
Require Import String.
Require Import List.
Open Scope string_scope.
Inductive Kind: Set :=
| Bool: Kind
| Struct: list (string * Kind) -> Kind.
Fixpoint type (k : Kind) : Type :=
match k with
| Bool => bool
| Struct list => let fix typeaux l : Type :=
match l with
| nil => unit
| (name,elem)::tail => ((type elem)*(typeaux tail))%type
end in typeaux list
end.
Example ex1 := Struct (("a",Bool)::("b",Bool)::nil).
Example ex2 := Struct (("s",ex1)::("t",ex1)::nil).
Eval compute in type ex2.
(* = (bool * (bool * unit) * (bool * (bool * unit) * unit))%type : Type *)
Hope it helps.
Best regards,
Michael
-----Original Message-----
coq-club-request AT inria.fr
[mailto:coq-club-request AT inria.fr]
On Behalf Of Murali Vijayaraghavan
Sent: Monday, December 15, 2014 6:47 AM
To:
Subject: [Coq-Club] Problem using heterogeneous lists for PHOAS
Hi all,
I am a novice in using Coq, so I apologize in advance if the answer to my
question is too trivial or has been answered before (I just got to know about
this mailing list recently).
So, I am trying to adopt the PHOAS method
(http://adam.chlipala.net/papers/PhoasICFP08/PhoasICFP08.pdf) to define a
language.
I have a kind definition as follows (containing booleans and C-structure-like
objects):
| Bool: Kind
I use heterogeneous lists whose definition is:
Section ilist.
Variable A : Type. (* The indexing type. *)
Variable B : A -> Type. (* The type of indexed elements. *)
Inductive ilist : list A -> Type :=
| icons : forall a As, B a -> ilist As -> ilist (a :: As)
| inil : ilist nil.
End ilist.
Now, I am trying to convert an element of the Kind into a Coq-native type
(like bool, or a heterogeneous list). I need heterogeneous lists because a
structure can contain other structures as in its elements.
In order to do this, I tried writing the following function [type]:
Fixpoint type (k: Kind): Type :=
match k with
| Bool => bool
| Struct attrs => ilist (fun a => snd a)
(map (fun a => (fst a, type (snd a))) attrs)
end.
This gives me Universe-inconsistency error. From my naive understanding of
Coq-universes, this error seems reasonable, since I am trying to create a
type which is quantified by elements, and these elements can in turn contain
the same type. But I am not sure if this explanation is correct.
I tried another variant of the same function:
match k with
| Bool => bool
| Struct attrs => ilist (fun a => type (snd a)) attrs
end.
This gives me the recursive call error: [Recursive call to type has principal
argument equal to "snd a" instead of "attrs"]. My understanding of this error
is that Coq is not able to figure out the decreasing argument of type, since
I am applying it on some argument, instead of on [attrs] directly.
This brings to my question: is there any way to write what I wanted to, which
is, convert values of my [Kind] into Coq-native types. I am open to using
some other [Type] instead of [ilist], if that can solve my problem.
Thanks
Murali
- [Coq-Club] Problem using heterogeneous lists for PHOAS, Murali Vijayaraghavan, 12/15/2014
- RE: [Coq-Club] Problem using heterogeneous lists for PHOAS, Soegtrop, Michael, 12/15/2014
- Re: [Coq-Club] Problem using heterogeneous lists for PHOAS, Murali Vijayaraghavan, 12/15/2014
- RE: [Coq-Club] Problem using heterogeneous lists for PHOAS, Soegtrop, Michael, 12/16/2014
