coq-club - RE: [Coq-Club] Problem using heterogeneous lists for PHOAS
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] Problem using heterogeneous lists for PHOAS
  • Date: Tue, 16 Dec 2014 08:34:23 +0000
  • Accept-language: de-DE, en-US
Dear Murali,
Interesting question. I must admit that I never thought about if equality of
pair types is easily decidable or not. I would think that using Type Classes
(see chapter 19 of the Coq reference manual), it should be easy to define a
pair of "types with decidable equality", which has then itself a decidable
quality. Does this solve your problem?
Otherwise the structural recursion method I showed should work equally well
with whatever type you want, so this problem should be solved. To solve your
Universe consistency problem, just create a binary tree type similar to your
list type. Then you won't need to use lists as elements of a list, but can
have an equivalent structure. In a binary tree, you can use the left child
pointer to represent depth and the right child pointer to represent siblings
in your record structure.
Best regards,
Michael
-----Original Message-----
coq-club-request AT inria.fr
[mailto:coq-club-request AT inria.fr]
On Behalf Of Murali Vijayaraghavan
Sent: Monday, December 15, 2014 7:50 PM
To:
Subject: Re: [Coq-Club] Problem using heterogeneous lists for PHOAS
Hi Michael
Thanks for the suggestion. It solves the problem I stated in the question.
But I have an issue using indexed types: I need to define decidable
(syntactic) equality of the values of [type k]. If I used an indexed type
(like [pair], or something which stores the field names also), then I can no
longer write a simple theorem checking if two prod-values are syntactically
equal. (I understand that using JMeq will solve this issue, but I am trying
to keep the equality semantics simple if possible, so that I can use rewrites
and reflexivity without any issues later). Is there any technique I can use
to keep the syntactic equality of these terms decidable?
Thanks
Murali
On Mon, Dec 15, 2014 at 6:14 AM, Soegtrop, Michael
wrote:
> Dear Murali,
> I am also a beginner, so I might be wrong in what I say, but let me comment
> on your problem.
> First I don't think you can make a heterogenous list and then use this list
> as an element type for the list. This should results in Universe errors, as
> you alreay observed. But since a list of lists is more or less equivalent
> to a tree, you can use a tree like data structure to describe your type.
> Second it is a bit tricky to do structural recursion on your Kind type,
> because you need to recurse over the Struct and the lists. I couldn't even
> get this to work with mutual recursion, but with so called internal
> recursion (see
> http://www.di.ens.fr/~zappa/teaching/coq/ecole11/summer/lectures/lec9.pdf)
> it works as below. Here I used simpel pairs to construct the type. You
> might want to use something more eloborate to make the structure clearer,
> but as I said before, I think it needs to be a tree like structure, not a
> list like structure. It should e.g. be possible to keep the record filed
> names in the types.
> Require Import String.
> Require Import List.
> Open Scope string_scope.
> Inductive Kind: Set :=
> | Bool: Kind
> | Struct: list (string * Kind) -> Kind.
> Fixpoint type (k : Kind) : Type :=
> match k with
> | Bool => bool
> | Struct list => let fix typeaux l : Type :=
> match l with
> | nil => unit
> | (name,elem)::tail => ((type elem)*(typeaux tail))%type
> end in typeaux list
> end.
> Example ex1 := Struct (("a",Bool)::("b",Bool)::nil).
> Example ex2 := Struct (("s",ex1)::("t",ex1)::nil).
> Eval compute in type ex2.
> (* = (bool * (bool * unit) * (bool * (bool * unit) * unit))%type :
> Type *)
> Hope it helps.
> Best regards,
> Michael
> From:
> On
> Sent: Monday, December 15, 2014 6:47 AM
> To:
> Subject: [Coq-Club] Problem using heterogeneous lists for PHOAS
> Hi all,
> I am a novice in using Coq, so I apologize in advance if the answer to my
> question is too trivial or has been answered before (I just got to know
> about this mailing list recently).
> So, I am trying to adopt the PHOAS method
> (http://adam.chlipala.net/papers/PhoasICFP08/PhoasICFP08.pdf) to define a
> language.
> I have a kind definition as follows (containing booleans and
> C-structure-like objects):
> | Bool: Kind
> I use heterogeneous lists whose definition is:
> Section ilist.
> Variable A : Type. (* The indexing type. *)
> Variable B : A -> Type. (* The type of indexed elements. *)
> Inductive ilist : list A -> Type :=
> | icons : forall a As, B a -> ilist As -> ilist (a :: As)
> | inil : ilist nil.
> End ilist.
> Now, I am trying to convert an element of the Kind into a Coq-native type
> (like bool, or a heterogeneous list). I need heterogeneous lists because a
> structure can contain other structures as in its elements.
> In order to do this, I tried writing the following function [type]:
> Fixpoint type (k: Kind): Type :=
> match k with
> | Bool => bool
> | Struct attrs => ilist (fun a => snd a)
> (map (fun a => (fst a, type (snd a))) attrs)
> end.
> This gives me Universe-inconsistency error. From my naive understanding of
> Coq-universes, this error seems reasonable, since I am trying to create a
> type which is quantified by elements, and these elements can in turn
> contain the same type. But I am not sure if this explanation is correct.
> I tried another variant of the same function:
> match k with
> | Bool => bool
> | Struct attrs => ilist (fun a => type (snd a)) attrs
> end.
> This gives me the recursive call error: [Recursive call to type has
> principal argument equal to "snd a" instead of "attrs"]. My understanding
> of this error is that Coq is not able to figure out the decreasing argument
> of type, since I am applying it on some argument, instead of on [attrs]
> directly.
> This brings to my question: is there any way to write what I wanted to,
> which is, convert values of my [Kind] into Coq-native types. I am open to
> using some other [Type] instead of [ilist], if that can solve my problem.
> Thanks
> Murali
