- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Using the [cut] tactic in hypothesis
- Date: Wed, 24 Dec 2014 18:44:04 -0500
I'm trying to simplify an hypothesis which contains something like this [a + - a = _] over Z (Let's call this hypothesis H).
So I thought it would be good to use the Zegal_left to do it, but Zegal_left do it the other way .. (i.e. It prove that [forall n m : Z, n = m -> n + - m = 0])
The rewrite tactic can be used to rewrite in hypothesis. Here is an example:
Require Import ZArith.
Open Scope Z_scope.
Lemma xyz : forall a:Z, a + - a = 2 -> False.
intros a H.
rewrite Zegal_left in H.
If H was a (sub)goal, I could have used the [cut] tactic, and it would have generated the [a=a] subgoal.
But because it's an hypothesis, I cannot use this tactic ..
I guess there is an easy workaround to do such a simplification in hypothesis ?
By the way, is-it possible, to directly rewrite this hypothesis ? Now, assume the hypothesis is of the form [0 = x0 * (x1 * a) + - a] (still over Z).
How can simplify it like [0=a * (x0 * x1 - 1)] ? (And how can I simplify it if it was a goal ?)
Use the ring properties of arithmetic on Z, e.g. associativity, commutativity, distributivity etc.
You can either manually invoke the ring lemmas, or assert the equality you want and prove it by the ring tactic.
I'll show the second option here:
Open Scope Z_scope.
Lemma xyzz : forall (x0 x1 a: Z),
x0 * (x1 * a) + - a = a * (x0 * x1 - 1).
intros.
ring.
Qed.
Lemma Z_0_or_not : forall z:Z, {z=0} + {z<>0}.I take this email to ask one little question that has no relation to the original subject.
What is the best to do a case disjunction on the value of a term during a proof ?
For example, if there is the term z:Z in the current goal, how do I create two subgoals with the hypothesis z=0 and z<>0 ?
Someone answered me on IRC to use the {}+{} types (sorry, I don't remember his name ..). It works very well, but I still have to prove the disjunction. So here is the extra question, how do I prove this :
Thanks in advance !
The lemma you are looking for is Z_zerop. Here's how I found it:
SearchPattern ( {?z=0} + {?z<>0}).
On bad days, I might have to issue more queries like
SearchPattern ( {?z<>0} + {?z = 0}).
SearchPattern ( {?z<>0} + {0 = ?z}).
.... i.e their might be a lemma with a logically equivalent, but syntactically different form.
My question to Coq gurus : Is there a smarter version of SearchPattern?
Regards,
-- Abhishek
http://www.cs.cornell.edu/~aa755/- [Coq-Club] Using the [cut] tactic in hypothesis, CHAUVIN Barnabe, 12/24/2014
- Re: [Coq-Club] Using the [cut] tactic in hypothesis, Abhishek Anand, 12/25/2014
- Re: [Coq-Club] Using the [cut] tactic in hypothesis, Jonathan Leivent, 12/25/2014
- Re: [Coq-Club] Using the [cut] tactic in hypothesis, CHAUVIN Barnabe, 12/28/2014
- Re: [Coq-Club] Using the [cut] tactic in hypothesis, Frédéric Besson, 12/28/2014
