coq-club - Re: [Coq-Club] Using the [cut] tactic in hypothesis
  • From: Frédéric Besson <frederic.besson AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Using the [cut] tactic in hypothesis
  • Date: Sun, 28 Dec 2014 17:58:03 +0100
> On 28 déc. 2014, at 17:02, CHAUVIN Barnabe
> <barnabe.chauvin AT gmail.com>
> wrote:
> Thank you for your answer ! This is much clearer :)
> I have another question, not really related to the [cut] tactic :
> I have the following hypothesis :
> x : Z
> y : Z
> H : x * y = 1
> H1 : x <> 1
> H2 : x <> -1
> How can I prove the contradiction here ?
Unfortunately, the proof requires some interaction :(
Require Import ZArith Psatz.
Open Scope Z_scope.
Goal forall
(x : Z) (y : Z)
(H : x * y = 1)
(H1 : x <> 1)
(H2 : x <> -1), False.
Proof.
intros.
assert (y >= 0 \/ y <= 0) by lia.
nia.
Qed.
> On 25/12/2014 00:44, Abhishek Anand wrote:
>> I'm trying to simplify an hypothesis which contains something like this [a
>> + - a = _] over Z (Let's call this hypothesis H).
>> So I thought it would be good to use the Zegal_left to do it, but
>> Zegal_left do it the other way .. (i.e. It prove that [forall n m : Z, n =
>> m -> n + - m = 0])
>> The rewrite tactic can be used to rewrite in hypothesis. Here is an
>> example:
>> Require Import ZArith.
>> Open Scope Z_scope.
>> Lemma xyz : forall a:Z, a + - a = 2 -> False.
>> intros a H.
>> rewrite Zegal_left in H.
>> If H was a (sub)goal, I could have used the [cut] tactic, and it would
>> have generated the [a=a] subgoal.
>> But because it's an hypothesis, I cannot use this tactic ..
>> I guess there is an easy workaround to do such a simplification in
>> hypothesis ?
>> By the way, is-it possible, to directly rewrite this hypothesis ? Now,
>> assume the hypothesis is of the form [0 = x0 * (x1 * a) + - a] (still over
>> Z).
>> How can simplify it like [0=a * (x0 * x1 - 1)] ? (And how can I simplify
>> it if it was a goal ?)
>> Use the ring properties of arithmetic on Z, e.g. associativity,
>> commutativity, distributivity etc.
>> http://en.wikipedia.org/wiki/Ring_%28mathematics%29
>> You can either manually invoke the ring lemmas, or assert the equality you
>> want and prove it by the ring tactic.
>> I'll show the second option here:
>> Open Scope Z_scope.
>> Lemma xyzz : forall (x0 x1 a: Z),
>> x0 * (x1 * a) + - a = a * (x0 * x1 - 1).
>> intros.
>> ring.
>> Qed.
>> I take this email to ask one little question that has no relation to the
>> original subject.
>> What is the best to do a case disjunction on the value of a term during a
>> proof ?
>> For example, if there is the term z:Z in the current goal, how do I create
>> two subgoals with the hypothesis z=0 and z<>0 ?
>> Someone answered me on IRC to use the {}+{} types (sorry, I don't remember
>> his name ..). It works very well, but I still have to prove the
>> disjunction. So here is the extra question, how do I prove this :
>> Lemma Z_0_or_not : forall z:Z, {z=0} + {z<>0}.
>> Thanks in advance !
>> The lemma you are looking for is Z_zerop. Here's how I found it:
>> SearchPattern ( {?z=0} + {?z<>0}).
>> On bad days, I might have to issue more queries like
>> SearchPattern ( {?z<>0} + {?z = 0}).
>> SearchPattern ( {?z<>0} + {0 = ?z}).
>> .... i.e their might be a lemma with a logically equivalent, but
>> syntactically different form.
>> My question to Coq gurus : Is there a smarter version of SearchPattern?
>> Regards,
>> -- Abhishek
>> http://www.cs.cornell.edu/~aa755/
