coq-club - Re: [Coq-Club] toy language
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] toy language
  • Date: Wed, 7 Jan 2015 18:20:09 -0800
Amin & Cedric,
Thank you for your suggestions. It was very helpful. I changed my type to
make "o" dependent
on "i" and it simplified things a bit. I tried to make "A" and "i" explicit,
but it turns out it is more terse to have them implicit as there are not too
many cases where I have to use "@".
Unfortunately there are few more cases which still lead to unsolved
obligations and I have to resort back to "Program" to solve them. Here is the
example modified by adding two more operators: Vhalf and Vconst. With these
two operators I want to illustrate two patterns I encounter in my operator
language:
1. Fixed size of input vector {H:i=1}.
2. Input vector size is twice the output: {H:i=o+o}
Unfortunately these lead to obligations in 'eval'. My first question is there
is a better
way to represent these 2 patterns?
Require Import Program.
Require Import Vector.
Import Vector.VectorNotations.
Inductive Vop {A:Type} {i:nat} : nat -> Type :=
| Vid: Vop i
| Vduplicate: Vop (i + i)
| Vhalf {o:nat} {H:i=o+o}: Vop o
| Vconst {o:nat} {H:i=1}: Vop o
| Vcompose : forall t o, @Vop A t o -> @Vop A i t -> @Vop A i o
(* Helper function *)
Definition take {A} {m} (p:nat) : Vector.t A (p+m) -> Vector.t A p. admit.
Defined.
Program Fixpoint eval {A:Type} {i o:nat} (t:@Vop A i o) (x:Vector.t A i):
Vector.t A o :=
match t with
| Vid => x
| Vhalf o H => take (m:=o) o x
| Vduplicate => Vector.append x x
| Vconst o H => Vector.const (hd (n:=0) x) o
| Vcompose _ _ vop1 vop2 => ((eval vop1) ∘ (eval vop2)) x
end.
Lemma test1:
forall A n (v:Vector.t A n),
eval (Vcompose _ _ (Vduplicate) (Vid)) v = eval (Vduplicate) v.
Proof.
trivial.
Qed.
Lemma test2:
forall A n {n2:nat} {H:n2=n+n} (v:Vector.t A n2) ,
eval (Vcompose _ _ (Vhalf (H:=H)) (Vid)) v = eval (Vhalf (H:=H) (o:=n))
v.
Proof.
intros.
unfold eval.
trivial.
Qed.
We are lucky the second lemma is also solved by "trivial", but in some more
complex situations
where I have a complex expression constructed from many operators "trivial"
does not work.
My second question/thought is about dealing with coercions in the eval code.
For example I have {H:i=1} and implementation expects vector of type (vector
A 1) I have auto generated type coercion from (vector A i) to (vector A 1)
using eq_rect and "H". When I am trying to prove something about this code I
have to deal with this eq_rect. I would love to be able to get rid of this
coercion, and instead add "H" to my proof context. Perhaps it is better
illustrated by an example:
Inductive T {i:nat} : Type :=
| T1 {H:i=1}: T.
Definition f {A:Type} (x:Vector.t A 1) : A := hd x.
Program Definition evalT {i:nat} (o:@T i) {A:Type} (x:Vector.t A i) : A :=
match o with
| T1 H => f x
end.
If we try to prove something like:
Lemma bad: forall (x:nat) {H:1=1},
evalT (T1 (H:=H)) [x] = x.
Proof.
intros.
unfold evalT.
we will end up with:
1 subgoals, subgoal 1 (ID 193)
x : nat
H : 1 = 1
f
(eq_rect 1 (fun H0 : nat => t nat H0) [x] 1
(evalT_obligation_1 1 T1 nat [x] H eq_refl)) = x
but what we are actually proving here is that: "f [x] = x" under
the assumption that length of [x] is 1. Which could be said as
the type of [x] is (vector nat i) and {i=1}. Something like:
x : nat
H : i = 1
v : vector nat i
A : v = [x]
f v = x
I am looking for a generic way dealing with such cases. Perhaps I should
define 'eval' differently, or maybe I can resort to some tactics which will
fold these coercions into
form shown above?
Thanks!
Sincerely,
Vadim Zaliva
