- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] toy language
- Date: Thu, 8 Jan 2015 10:13:56 +0100
I would still insist on not using equality proofs.
Inductive Vop_i {A:Type} (i:nat) : nat -> Type :=
| Vid: Vop_i i i
| Vduplicate: Vop_i i (i + i)
Inductive Vop_o {A:Type} (o:nat) : nat -> Type :=
| Vhalf : Vop_o o (o + o)
| Vconst : Vop_o o 1
Inductive Vop {A : Type} {i o : nat} :=
| VI : @Vop_i A i o -> Vop
| VO : @Vop_o A o i -> Vop
| Vcompose : forall t, @Vop A t o -> @Vop A i t -> @Vop A i o
(* Helper function *)
Definition take {A} {m} (p:nat) : Vector.t A (p+m) -> Vector.t A p. admit.
Defined.
Definition eval_i {A:Type} {i o:nat} (t:@Vop_i A i o) (x:Vector.t A i):
Vector.t A o :=
match t with
| Vid => x
| Vduplicate => Vector.append x x
end.
Definition eval_o {A:Type} {i o:nat} (t:@Vop_o A o i) (x:Vector.t A i):
Vector.t A o :=
(match t in @Vop_o _ _ i return Vector.t A i -> Vector.t A o
with
| Vhalf => fun y => take (m:=o) o y
| Vconst => fun y => Vector.const (hd (n:=0) y) o
end) x.
Fixpoint eval {A:Type} {i o:nat} (t:@Vop A i o) (x:Vector.t A i): Vector.t A
o :=
match t with
| VI vi => eval_i vi x
| VO vo => eval_o vo x
| Vcompose _ vop1 vop2 => ((eval vop1) ∘ (eval vop2)) x
end.
Lemma test1:
forall A n (v:Vector.t A n),
eval (Vcompose _ (VI (Vduplicate _)) (VI (Vid _))) v = eval (VI
(Vduplicate _)) v.
Proof.
trivial.
Qed.
Lemma test2:
forall A n (v:Vector.t A (n + n)) ,
eval (Vcompose _ (VO (Vhalf _)) (VI (Vid _))) v = eval (VO (Vhalf _)) v.
Proof.
trivial.
Qed.
> On 08 Jan 2015, at 03:20, Vadim Zaliva
> <vzaliva AT cmu.edu>
> wrote:
> Amin & Cedric,
> Thank you for your suggestions. It was very helpful. I changed my type to
> make "o" dependent
> on "i" and it simplified things a bit. I tried to make "A" and "i"
> explicit, but it turns out it is more terse to have them implicit as there
> are not too many cases where I have to use "@".
> Unfortunately there are few more cases which still lead to unsolved
> obligations and I have to resort back to "Program" to solve them. Here is
> the example modified by adding two more operators: Vhalf and Vconst. With
> these two operators I want to illustrate two patterns I encounter in my
> operator language:
> 1. Fixed size of input vector {H:i=1}.
> 2. Input vector size is twice the output: {H:i=o+o}
> Unfortunately these lead to obligations in 'eval'. My first question is
> there is a better
> way to represent these 2 patterns?
> Require Import Program.
> Require Import Vector.
> Import Vector.VectorNotations.
> Inductive Vop {A:Type} {i:nat} : nat -> Type :=
> | Vid: Vop i
> | Vduplicate: Vop (i + i)
> | Vhalf {o:nat} {H:i=o+o}: Vop o
> | Vconst {o:nat} {H:i=1}: Vop o
> | Vcompose : forall t o, @Vop A t o -> @Vop A i t -> @Vop A i o
> Defined.
> Program Fixpoint eval {A:Type} {i o:nat} (t:@Vop A i o) (x:Vector.t A i):
> Vector.t A o :=
> match t with
> | Vid => x
> | Vhalf o H => take (m:=o) o x
> | Vconst o H => Vector.const (hd (n:=0) x) o
> | Vcompose _ _ vop1 vop2 => ((eval vop1) ∘ (eval vop2)) x
> end.
> Lemma test1:
> eval (Vcompose _ _ (Vduplicate) (Vid)) v = eval (Vduplicate) v.
> Proof.
> trivial.
> Qed.
> Lemma test2:
> forall A n {n2:nat} {H:n2=n+n} (v:Vector.t A n2) ,
> eval (Vcompose _ _ (Vhalf (H:=H)) (Vid)) v = eval (Vhalf (H:=H) (o:=n))
> v.
> Proof.
> intros.
> unfold eval.
> trivial.
> Qed.
> We are lucky the second lemma is also solved by "trivial", but in some more
> complex situations
> where I have a complex expression constructed from many operators "trivial"
> does not work.
> My second question/thought is about dealing with coercions in the eval
> code. For example I have {H:i=1} and implementation expects vector of type
> (vector A 1) I have auto generated type coercion from (vector A i) to
> (vector A 1) using eq_rect and "H". When I am trying to prove something
> about this code I have to deal with this eq_rect. I would love to be able
> to get rid of this coercion, and instead add "H" to my proof context.
> Perhaps it is better illustrated by an example:
> Inductive T {i:nat} : Type :=
> | T1 {H:i=1}: T.
> Definition f {A:Type} (x:Vector.t A 1) : A := hd x.
> Program Definition evalT {i:nat} (o:@T i) {A:Type} (x:Vector.t A i) : A :=
> match o with
> | T1 H => f x
> end.
> If we try to prove something like:
> Lemma bad: forall (x:nat) {H:1=1},
> evalT (T1 (H:=H)) [x] = x.
> Proof.
> intros.
> unfold evalT.
> we will end up with:
> 1 subgoals, subgoal 1 (ID 193)
> x : nat
> H : 1 = 1
> f
> (eq_rect 1 (fun H0 : nat => t nat H0) [x] 1
> (evalT_obligation_1 1 T1 nat [x] H eq_refl)) = x
> but what we are actually proving here is that: "f [x] = x" under
> the assumption that length of [x] is 1. Which could be said as
> the type of [x] is (vector nat i) and {i=1}. Something like:
> x : nat
> H : i = 1
> v : vector nat i
> A : v = [x]
> f v = x
> I am looking for a generic way dealing with such cases. Perhaps I should
> define 'eval' differently, or maybe I can resort to some tactics which will
> fold these coercions into
> form shown above?
> Thanks!
> Sincerely,
> Vadim Zaliva
- [Coq-Club] toy language, Vadim Zaliva, 01/07/2015
- Re: [Coq-Club] toy language, Amin Timany, 01/07/2015
- Re: [Coq-Club] toy language, Cedric Auger, 01/07/2015
- Re: [Coq-Club] toy language, Vadim Zaliva, 01/08/2015
- Re: [Coq-Club] toy language, Amin Timany, 01/08/2015
- Re: [Coq-Club] toy language, Cedric Auger, 01/08/2015
- Re: [Coq-Club] toy language, Vadim Zaliva, 01/09/2015
- Re: [Coq-Club] toy language, Vadim Zaliva, 01/10/2015
- Re: [Coq-Club] toy language, Cedric Auger, 01/10/2015
- Re: [Coq-Club] toy language, Vadim Zaliva, 01/12/2015
