- To: coq-club AT inria.fr
- Subject: [Coq-Club] toy language
- Date: Tue, 6 Jan 2015 19:21:46 -0800
Hi!
I want to solicit some advise on designing proper representation for a simple
language. Let us say we have a language which operates on vectors of type
{A}. Each operator takes as an input a vector of size {i} and returns as an
output a vector of size {o}. I've described the language by the following
inductive type:
Require Import Program.
Require Import Vector.
Import Vector.VectorNotations.
Inductive Vop {A:Type} {i o:nat}: Type :=
| Vid {H:i=o}: Vop
| Vappend {H:o=i+i}: Vop
| Vcompose {t:nat}: @Vop A t o -> @Vop A i t -> @Vop A i o
Now I can write 'eval' function which takes an operator (t:Vop) and input
vector {x}
of size {i} and returns a resulting vector of size {o}:
Program Fixpoint eval {A:Type} {i o:nat} (t:@Vop A i o) (x:Vector.t A i):
Vector.t A o :=
match t with
| Vid _ => x
| Vappend H => Vector.append x x
| Vcompose _ vop1 vop2 => ((eval vop1) ∘ (eval vop2)) x
end.
Solve All Obligations using auto with arith.
So far so good. Now let us try to prove a simple lemma:
Lemma test:
forall A d n (v:Vector.t A n) {H:d=n+n} {H1:n=n},
eval (
Vcompose
(Vappend (H:=H))
(Vid (H:=H1) (o:=n)))
v
eval (Vappend (H:=H) (o:=d))
v.
Once I try to prove this lemma I can see that it gets pretty messy due to
'eq_rect', lambda expressions and obligations which are part of the 'eval'
definition:
Proof.
intros.
unfold eval.
1 subgoals, subgoal 1 (ID 93)
A : Type
d : nat
n : nat
v : t A n
H : d = n + n
H1 : n = n
((fun x : t A n =>
eq_rect (n + n) (fun H0 : nat => t A H0) (append x x) d
(eval_obligation_2 A n d Vappend x H eq_refl))
∘ (fun x : t A n =>
eq_rect n (fun H0 : nat => t A H0) x n
(eval_obligation_1 A n n Vid x H1 eq_refl))) v =
eq_rect (n + n) (fun H0 : nat => t A H0) (append v v) d
(eval_obligation_2 A n d Vappend v H eq_refl)
It is also looks a bit weird to provide {H1:n=n} implicitly.
This is a simplified example and my actual language will be more complex but
it illustrates the kind of problems I am running into.
Perhaps I am doing it wrong and there is a better way to define such language?
Your advice is greatly appreciated.
Sincerely,
Vadim Zaliva
- [Coq-Club] toy language, Vadim Zaliva, 01/07/2015
- Re: [Coq-Club] toy language, Amin Timany, 01/07/2015
- Re: [Coq-Club] toy language, Cedric Auger, 01/07/2015
- Re: [Coq-Club] toy language, Vadim Zaliva, 01/08/2015
- Re: [Coq-Club] toy language, Amin Timany, 01/08/2015
- Re: [Coq-Club] toy language, Cedric Auger, 01/08/2015
- Re: [Coq-Club] toy language, Vadim Zaliva, 01/09/2015
- Re: [Coq-Club] toy language, Vadim Zaliva, 01/10/2015
- Re: [Coq-Club] toy language, Cedric Auger, 01/10/2015
- Re: [Coq-Club] toy language, Vadim Zaliva, 01/12/2015
