[Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file
- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file
- Date: Wed, 14 Jan 2015 10:32:16 +0000
- Accept-language: de-DE, en-US
Dear Coq users,
I get errors compiling ssreflect 1.5 with Ocaml 4.01.0. Unfortunately the
ssreflect INSTALL file doesn't mention an recommended Ocaml version.
As it look I am not the only one getting these errors, see e.g.:
http://www.lix.polytechnique.fr/coq/pylons/logs/view/ReleasedSsreflect/3069174337681179041
I get the same errors about deprecated syntax, which are trivial to fix. In
addition I get this error:
File "src/ssreflect.ml4", line 843, characters 21-22:
Parse error: [fun_def_cont] expected (in [fun_def])
Error while running external preprocessor
which at least for me is not trivial to fix. Did someone compile ssreflect
1.5 with Ocaml 4.01.0?
In case it makes a difference: I use the Coq 8.4pl5 (compiled from sources
using the same Ocaml).
The ssreflect INSTALL file mentions that "Coq version 8.4 compiled with
CamlP5" is required. I am not sure I understand the dependency on CamlP5. I
compiled Coq 8.4pl5 from sources ant it works fine (e.g. CompCert and VST
builds run through fine). I also compiled and installed CamlP5 before
building ssreflect, but I am not sure I understand what is meant by "Coq
compiled with CamlP5". Should I compile Coq in some different non standard
way in order to be able to compile ssreflect 1.5?
Best regards,
Michael
- [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file, Soegtrop, Michael, 01/14/2015
- Re: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file, Enrico Tassi, 01/14/2015
- RE: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file, Soegtrop, Michael, 01/14/2015
- Re: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file, Bernhard Schommer, 01/14/2015
- RE: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file, Soegtrop, Michael, 01/15/2015
