Re: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file
- From: Bernhard Schommer <bernhardschommer AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file
- Date: Wed, 14 Jan 2015 19:57:04 +0100
Dear Michael,
just a small remark, the current repo version of compcert needs an ocaml version >= 4.00.
Cheers,
Bernhard Schommer
Am 14.01.2015 um 17:30 schrieb Enrico Tassi:
On Wed, Jan 14, 2015 at 04:24:18PM +0000, Soegtrop, Michael wrote:
One more question: Should ssreflect 1.5 compile fine with Ocaml 4.X?It compiles fine with 4.0.1, didn't test with 4.0.2.
Is Ocaml 3.X or Ocaml 4.X the preferred version?
3.12 is fine too.
Btw.: ssreflect ist not listed in the Opam package list atThe link I gave you is a repository of coq specific packages.
https://opam.ocaml.org/packages/ which is another reason why I decided
Opam can fetch from multiple repositories.
Ciao
- [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file, Soegtrop, Michael, 01/14/2015
- Re: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file, Enrico Tassi, 01/14/2015
- RE: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file, Soegtrop, Michael, 01/14/2015
- Re: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file, Bernhard Schommer, 01/14/2015
- RE: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file, Soegtrop, Michael, 01/15/2015
