coq-club - RE: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 - Question on ssreflect INSTALL file
  • Date: Wed, 14 Jan 2015 16:24:18 +0000
  • Accept-language: de-DE, en-US
Dear Enrico,
ah, this explains it. I didn't understand how to tell the Coq make system
that camlp5 is there, so I didn't try to just build it before. I guess adding
your statement "install camlp5 *before* configuring coq. It will detect it
and use it instead of camlp4" to the ssreflect INSTALL file might help
others. It was not clear to me what exactly to do with camlp5 from the
ssreflect INSTALL file.
One more question: Should ssreflect 1.5 compile fine with Ocaml 4.X? Is Ocaml
3.X or Ocaml 4.X the preferred version?
I considered using Opam, but since compiling everything from sources is quite
easy (except for ssreflect), I decided against it.
Btw.: ssreflect ist not listed in the Opam package list at
https://opam.ocaml.org/packages/ which is another reason why I decided
against using Opam. I think I saw an ssreflect opam package on a site from,
if I remember right, Thomas Braibant, but I was unsure how well maintained
this is.
Best regards,
Michael
-----Original Message-----
coq-club-request AT inria.fr
[mailto:coq-club-request AT inria.fr]
On Behalf Of Enrico Tassi
Sent: Wednesday, January 14, 2015 5:03 PM
To:
Subject: Re: [Coq-Club] Errors compiling ssreflect 1.5 using Ocaml 4.01.0 -
On Wed, Jan 14, 2015 at 03:46:59PM +0000, Soegtrop, Michael wrote:
> Dear Enrico,
> I am on Ubuntu 12.04 LTS, but I don't have root rights, which makes
> package installtion complicated. Compile everything from sources seems
> to be easier. Also I prefer to know exactly what I have.
If you really want to do things by hand, then install camlp5 *before*
configuring coq. It will detect it and use it instead of camlp4.
Installing it afterwards is not an option, both coq and ssreflect must be
compiled with it.
If your system happens to have opam installed or you manage to install it
manually then I recommend you follow the instructions here:
https://github.com/coq/repo-stable
There are not many packages available, but ssreflect 1.5 and compcert
2.4 are there.
Best,
Enrico Tassi
