- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] pigeon hole principal
- Date: Thu, 15 Jan 2015 12:17:44 -0800
Thanks Frederic, i will see, if i can draw any tricks to complete my proof.
Also, thanks Ben for the pointers.
On Thu, Jan 15, 2015 at 10:15 AM, Ben
<midfield AT gmail.com>
wrote:
> here are some useful links:
> https://sympa.inria.fr/sympa/arc/coq-club/2014-11/msg00124.html
> https://gist.github.com/anonymous/e9493ce195219c4c2b18
> i tried to do it myself i failed -- i'm just a beginner. at some point i
> convinced myself that the right way to do it is
> - prove pigeonhole for lists of nats (using decidable equality)
> - convert the general problem into a problem about lists of nats by using
> indices
> but i got bogged down in details. also there's a Prop vs Type issue with
> appears_in, i think.
> best, ben
>> On Jan 15, 2015, at 12:14 AM, Jiten Pathy
>> <jpathy AT fssrv.net>
>> wrote:
>> Hello,
>> Trying to prove pigeon hole from SF using excluded_middle. Stuck while
>> doig the following. A hint on what i am doing wrong?
>> https://gist.github.com/anonymous/548325557388612bd60e
- [Coq-Club] pigeon hole principal, Jiten Pathy, 01/15/2015
- Re: [Coq-Club] pigeon hole principal, Frédéric Blanqui, 01/15/2015
- Re: [Coq-Club] pigeon hole principal, Ben, 01/15/2015
- Re: [Coq-Club] pigeon hole principal, Jiten Pathy, 01/15/2015
- Re: [Coq-Club] pigeon hole principal, gallais, 01/16/2015
- Re: [Coq-Club] pigeon hole principal, Daniel Schepler, 01/16/2015
