coq-club - [Coq-Club] heterogeneous tuple element function
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] heterogeneous tuple element function
  • Date: Thu, 15 Jan 2015 17:41:24 -0500
I would like to write a recursive function that takes 3 arguments: an element index (0-based), a count of elements, and a heterogeneous tuple containing (usually) that many elements - and have it return the indexed element of the tuple if it exists. If the tuple doesn't contain the right number of elements, I don't care what the function does, and I don't want to provide a proof that the tuple contains the right number of elements. The index < count - and if not, then I don't care what the function does.
Notes: the tuple arg will be strictly right-associated. If count =1, then the third arg is just an arbitrarily-typed singleton, and is the result itself. If count>1, then the last element is the snd of the last pair, while all previous elements are the fst of some pair.
I know how to do this when the container is homogeneous, as with lists or vectors - but not with hetero tuples. I don't even know how to write the type of the function in this case.
Also, I think I may have seen the solution to this somewhere - but don't remember where... Was it in CPDT somewhere?
Any clues on how to write this function?
Thanks,
-- Jonathan
