- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] pigeon hole principal
- Date: Fri, 16 Jan 2015 00:39:43 +0000
If you are willing to have membership / repeat predicates living
in Type (it is needed to write the `remove` function) then there
is a fairly simple constructive solution:
https://github.com/gallais/potpourri/blob/master/agda/poc/PigeonHole.agda
Now, it should not be too hard to move from a Prop-based formulation
to a Type-based one if you can decide equality of elements: you can
recover a membership predicate in Type by searching the list for an
element (decidable equality!) with the guarantee to find one (Prop-
based membership predicate!).
On 15/01/15 18:15, Ben wrote:
here are some useful links:
https://sympa.inria.fr/sympa/arc/coq-club/2014-11/msg00124.html
https://gist.github.com/anonymous/e9493ce195219c4c2b18
i tried to do it myself i failed -- i'm just a beginner. at some point i
convinced myself that the right way to do it is
- prove pigeonhole for lists of nats (using decidable equality)
- convert the general problem into a problem about lists of nats by using
indices
but i got bogged down in details. also there's a Prop vs Type issue with
appears_in, i think.
best, ben
On Jan 15, 2015, at 12:14 AM, Jiten Pathy
<jpathy AT fssrv.net>
wrote:
Hello,
Trying to prove pigeon hole from SF using excluded_middle. Stuck while
doig the following. A hint on what i am doing wrong?
https://gist.github.com/anonymous/548325557388612bd60e
- [Coq-Club] pigeon hole principal, Jiten Pathy, 01/15/2015
- Re: [Coq-Club] pigeon hole principal, Frédéric Blanqui, 01/15/2015
- Re: [Coq-Club] pigeon hole principal, Ben, 01/15/2015
- Re: [Coq-Club] pigeon hole principal, Jiten Pathy, 01/15/2015
- Re: [Coq-Club] pigeon hole principal, gallais, 01/16/2015
- Re: [Coq-Club] pigeon hole principal, Daniel Schepler, 01/16/2015
