coq-club - Re: [Coq-Club] heterogeneous tuple element function
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] heterogeneous tuple element function
  • Date: Fri, 16 Jan 2015 05:37:03 +0400
I don't know Coq much, so my answer will be in Agda.
Vilhelm Sjöberg, this ``tt'' at the end looks confusing. Agda has
non-empty vectors (the _^_ operator), which are handy in this case:
HList : ∀ {α} n -> Set α ^ n -> Set α
HList 0 _ = Lift ⊤
HList 1 X = X
HList (suc (suc n)) (X , Xs) = X × HList (ℕ.suc n) Xs
lookup-^ : ∀ {n α} {A : Set α} -> (i : Fin n) -> A ^ n -> A
lookup-^ {1} zero x = x
lookup-^ {suc (suc n)} zero (x , xs) = x
lookup-^ {1} (suc ())
lookup-^ {suc (suc n)} (suc i) (x , xs) = lookup-^ i xs
get : ∀ n {Xs : Set ^ n} -> (i : Fin n) -> HList n Xs -> lookup-^ i Xs
get 1 zero x = x
get (suc (suc n)) zero (x , xs) = x
get 1 (suc ())
get (suc (suc n)) (suc i) (x , xs) = get _ i xs
test : get 4 (Fin.suc (Fin.suc Fin.zero)) (1 , tt , 42 , true) ≡ 42
test = refl
Agda can infer all types automatically. To get rid of this
``Fin.suc``s we can define a generic combinator
Default : ∀ {n} -> Set -> (Fin n -> Set) -> ℕ -> Set
Default {0} A F m = A
Default {suc n} A F 0 = F Fin.zero
Default {suc n} A F (suc m) = Default A (F ∘ Fin.suc) m
default : ∀ {n} {A : Set} {C : Fin n -> Set}
-> A -> ((i : Fin n) -> C i) -> ∀ m -> Default A C m
default {0} x f m = x
default {suc n} x f 0 = f Fin.zero
default {suc n} x f (suc m) = default x (f ∘ Fin.suc) m
and use it:
_≢0 : ℕ -> Set
0 ≢0 = ⊥
_ ≢0 = ⊤
getᴺ : ∀ n {Xs : Set ^ n}
-> ∀ m {_ : m ≢0} -> HList n Xs -> Default {n} ⊤ (λ i ->
lookup-^ i Xs) (m ∸ 1)
getᴺ n m hs = default tt (λ i -> get n i hs) (m ∸ 1)
``getᴺ'' receives the length of a tuple and the index of an element.
If the index is bigger than the length, then ``getᴺ'' returns ``tt''.
test-2 : getᴺ 4 3 (1 , true , 42 , tt) ≡ 42
test-2 = refl
test-3 : getᴺ 4 5 (1 , true , 42 , 42) ≡ tt
test-3 = refl
It's also possible to write fully universe polymorphic ``HList'', so
you can write stuff like (1 , List Set , Set₁ , 42), but that's more
involved.
It's also possible to replace n-ary tuples with a datatype, that
represents heterogeneous vectors, so you can write something like
test : vgetᴺ 3 (1 ∷ true ∷ 42 ∷ tt ∷ []) ≡ 42
test = refl
but datatypes have more problems with universe polymorphism than functions.
The whole code: http://lpaste.net/118537
