- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] gprogress tactical?
- Date: Sat, 24 Jan 2015 20:22:32 -0500
On 01/24/2015 07:53 PM, Jason Gross wrote:
Nice! (The logic might be a bit easier to read with [tryif], perhaps?)
Sure, but then there would be a bunch of [else idtac]'s floating around. Maybe that's better, regardless.
Remind me what "?[__Any_flag]" means? Is it "new evar with name
?__Any_flag"? And why [try unify] rather than [unify]?
The truly ugly hack here is related to the hard-coded evar name ?__Any_flag. The form ?[__Any_flag] is as you say - it creates an evar with that name, but fails if one already exists. That failure case here is key - as that allows this tactic to break symmetry across the goals - so that exactly one goal can do some work (in this case, assert another trivial goal to have in case tac solves all goals) while the others don't bother. That could also sometimes be done with [> do work | don't do work..] - but in this case, the evar is also needed as a way to communicate information across goals - so two birds with one stone. The times where [> do work | don't do work..] would fail are if there are no goals - and in that case, the hard-coded evar trick can still succeed. Also note that allowing Coq to generate a fresh evar name and then get it via something like let E:=eval cbv delta [H] in H in ... would fail because such a let would lose the global focus - another reason to use a hard-coded evar name.
The "try unify" is because, once the first unify succeeds, the evar disappears, so subsequent unifies against it will fail.
-Jason
On Jan 24, 2015 1:40 PM, "Jonathan Leivent"
<jonikelee AT gmail.com>
wrote:
On 01/24/2015 03:27 PM, Jonathan Leivent wrote:
On 01/24/2015 10:29 AM, Jonathan Leivent wrote:Ltac any tac :=
On 01/24/2015 02:43 AM, Jason Gross wrote:A more general request: an "any" tactical which retains global focus and
Hi,I learned recently from Arnaud, by way of bug 3878, that attempting to
In trunk/8.5, is there a tactical that means "progresses in at least one
goal"? I tried `progress [> intros ]`, but this fails if any of the
goals
has no hypotheses to introduce, and I want it to fail only if all of the
goals have no hypotheses to introduce.
Thanks,
Jason
keep a global focus in tactic expressions is very difficult. None of the
tacticals - progress, once, try, etc.. - will keep a global focus. Hence
'progress [> intros ..]' is equivalent to '[> progress intros..]'.
-- Jonathan
succeeds if its arg tactic succeeds in at least one subgoal. In which
case, you could do: any (progress intros).
Actually - I might be able to write such an "any" tactical in Ltac - let
me work on it...
-- Jonathan
try (is_evar ?__Any_flag;
fail 1 "any: the evar name ?__Any_flag is being used");
try (let A:=fresh in
refine (let A:=?[__Any_flag]:bool in _);[shelve|];
assert True as _; clear A);
[> | try (try unify ?__Any_flag true; tac) ..];
[> try (is_evar ?__Any_flag;
fail 1 tac "failed on all subgoals");
exact I | ..].
Goal True.
pose proof 0 as n.
destruct n.
all: any ltac:(idtac).
all: any ltac:(revert n).
all: any ltac:(progress intros).
Fail all: any ltac:(progress intros).
all: any ltac:(exact I).
Qed.
Note - you can't make "any" into a Tactic Notation (or wrap a Tactic
Notation around it), as Tactic Notations always abandon global focus.
[Requesting a fix to this will result in some Coq developer informing you
that Tactic Notation is an abomination.]
-- Jonathan
- [Coq-Club] gprogress tactical?, Jason Gross, 01/24/2015
- Re: [Coq-Club] gprogress tactical?, Jonathan Leivent, 01/24/2015
- Re: [Coq-Club] gprogress tactical?, Pierre-Marie Pédrot, 01/25/2015
- Re: [Coq-Club] gprogress tactical?, Jonathan Leivent, 01/25/2015
- Re: [Coq-Club] gprogress tactical?, Jason Gross, 01/25/2015
- Re: [Coq-Club] gprogress tactical?, Arnaud Spiwack, 01/26/2015
- Re: [Coq-Club] gprogress tactical?, Jonathan Leivent, 01/26/2015
- Re: [Coq-Club] gprogress tactical?, Jason Gross, 01/26/2015
