coq-club - [Coq-Club] Applying a simplified hypothesis gives the original hypothesis in the proof term
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Applying a simplified hypothesis gives the original hypothesis in the proof term
  • Date: Mon, 2 Feb 2015 09:54:10 +0000
  • Accept-language: de-DE, en-US
Dear Coq users,
when I simplify a hypothesis and then apply it, the proof term contains the
original unsimplified hypothesis:
Require Import List.
Open Scope list_scope.
Import ListNotations.
Definition a := [1;2;3].
Definition x : list nat.
set (H:= [1;2;3] ++ [4;5;6] ).
compute in H.
exact H.
Defined.
Print x. (* Results in x = let H := [1; 2; 3] ++ [4; 5; 6] in H : list nat *)
This is a bit inconvenient, especially in connection with the new $( )$
syntax.
Of cause I can use "Eval compute in" or similar outside of $( )$ but in some
cases I want to be more selective in how to simplifiy which term.
I wonder if there is a way to get the simplified proof term in the proof term.
Btw.: "Eval compute in" doesn't work with "Instance", which might be a useful
feature in connection with $( )$.
Best regards,
Michael
