Re: [Coq-Club] Applying a simplified hypothesis gives the original hypothesis in the proof term
- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Applying a simplified hypothesis gives the original hypothesis in the proof term
- Date: Mon, 2 Feb 2015 13:38:49 +0100
This should be what you are after:
Definition x : list nat.
let h := constr:([1;2;3] ++ [4;5;6]) in
let h' := eval compute in h in
set (H:= h').
exact H.
Defined.
set (H:= h').
exact H.
Defined.
On 2 February 2015 at 10:54, Soegtrop, Michael <michael.soegtrop AT intel.com> wrote:
Dear Coq users,
when I simplify a hypothesis and then apply it, the proof term contains the original unsimplified hypothesis:
Require Import List.
Open Scope list_scope.
Import ListNotations.
Definition a := [1;2;3].
set (H:= [1;2;3] ++ [4;5;6] ).
compute in H.
exact H.
Defined.
Print x. (* Results in x = let H := [1; 2; 3] ++ [4; 5; 6] in H : list nat *)
This is a bit inconvenient, especially in connection with the new $( )$ syntax.
Of cause I can use "Eval compute in" or similar outside of $( )$ but in some cases I want to be more selective in how to simplifiy which term.
I wonder if there is a way to get the simplified proof term in the proof term.
Btw.: "Eval compute in" doesn't work with "Instance", which might be a useful feature in connection with $( )$.
Best regards,
Michael
- [Coq-Club] Applying a simplified hypothesis gives the original hypothesis in the proof term, Soegtrop, Michael, 02/02/2015
- Re: [Coq-Club] Applying a simplified hypothesis gives the original hypothesis in the proof term, Arnaud Spiwack, 02/02/2015
- RE: [Coq-Club] Applying a simplified hypothesis gives the original hypothesis in the proof term, Soegtrop, Michael, 02/02/2015
