- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to obtain the statement "n = S n'" within a match?
- Date: Sun, 8 Feb 2015 02:41:04 +0100
Hello,
It is much simpler (and efficient) to define nat_to_bin as follows:
Fixpoint sbin b :=
match b with
| O' => ST O'
| T b => ST b
| ST b => T (sbin b)
end.
Fixpoint nat_to_bin n :=
match n with
| O => O'
| S n => sbin (nat_to_bin n)
end.
(as you intend if I read correctly).
HOWEVER, your intended interpretation of bin is dangerous:
zero has many different representations (O', T O', etc.).
For instance you can prove forall n, interp (nat_to_bin n) = n
with
Fixpoint interp b :=
match b with
| O' => O
| T b => let n := interp b in n + n
| ST b => let n := interp b in S (n + n)
end.
But the converse does not hold because you would need O' = T O'.
The usual trick is to consider that bin represents only
positive nats, that is to interpret O' as 1 instead of 0:
match b with
| O' => (S O)
end.
Fixpoint sbin b :=
match b with
| O' => T O'
| T b => ST b
| ST b => T (sbin b)
end.
Fixpoint Snat_to_bin n :=
match n with
| O => O'
| S n => sbin (Snat_to_bin n)
end.
(* nat_to_bin O is considered as irrelevant *)
Definition nat_to_bin n := Snat_to_bin (pred n).
Then you can check:
Theorem interp_nat_to_bin : forall n, interp (nat_to_bin (S n)) = S n.
Theorem nat_to_bin_interp : forall b, nat_to_bin (interp b) = b.
Hope this helps,
JFM
On Sat, Feb 07, 2015 at 06:33:25PM -0500, Holden Lee wrote:
> I define "strong" recursion for natural numbers:
> Definition strong_rec (P: nat -> Type) :
> (forall n: nat,
> (forall m: nat, (m<n) -> P m) -> P n) -> (forall m: nat, P m).
> Now I try to define a function to convert from unary to binary:
> Definition nat_to_bin : (nat -> bin) :=
> strong_rec (fun _ => bin) (fun n => (fun F =>
> match n with
> | O => O'
> | S n' =>
> match (div2rem n) with
> | (x, O) => T (F (fst (div2rem (S n'))) (div2smaller n'))
> | (x, S y) => ST (F (fst (div2rem (S n'))) (div2smaller n'))
> end
> end)).
> Basically I define nat_to_bin n in terms of nat_to_bin (n/2)
> Here div2smaller n' is a proof that (S n')/2<S n' so that we can use
> strong_rec.
> Lemma div2smaller:
> forall n, fst (div2rem (S n))<S n.
> However this gives the error
> Error:
> In environment
> n : nat
> F : forall m : nat, m < n -> bin
> n' : nat
> x : nat
> n0 : nat
> The term "div2smaller n'" has type "fst (div2rem (S n')) < S n'"
> while it is expected to have type "fst (div2rem (S n')) < n".
> How can I tell Coq that n=S n'?
> For reference here is the definition for bin:
> Inductive bin : Type :=
> | O' : bin
> | T : bin -> bin (*twice*)
> | ST: bin -> bin. (*one more than twice*)
> Thanks,
> Holden
Jean-Francois Monin
- [Coq-Club] How to obtain the statement "n = S n'" within a match?, Holden Lee, 02/08/2015
- Re: [Coq-Club] How to obtain the statement "n = S n'" within a match?, Cedric Auger, 02/08/2015
- Re: [Coq-Club] How to obtain the statement "n = S n'" within a match?, Jean-Francois Monin, 02/08/2015
- Re: [Coq-Club] How to obtain the statement "n = S n'" within a match?, Kristopher Micinski, 02/08/2015
