- From: Kristopher Micinski <krismicinski AT gmail.com>
- To: coq club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] How to obtain the statement "n = S n'" within a match?
- Date: Sun, 8 Feb 2015 14:02:42 -0500
Adam Chlipala's book has a trick that he calls the "Convoy pattern" in
the chapter `MoreDep`,
http://adam.chlipala.net/cpdt/html/MoreDep.html
It has been very useful (to me, at least) for tackling this general
problem of needing to carry around these extra proofs with you through
a dependent match.
Kris
On Sat, Feb 7, 2015 at 6:33 PM, Holden Lee
<holdenlee AT alum.mit.edu>
wrote:
> I define "strong" recursion for natural numbers:
> Definition strong_rec (P: nat -> Type) :
> (forall n: nat,
> (forall m: nat, (m<n) -> P m) -> P n) -> (forall m: nat, P m).
> Now I try to define a function to convert from unary to binary:
> Definition nat_to_bin : (nat -> bin) :=
> strong_rec (fun _ => bin) (fun n => (fun F =>
> match n with
> | O => O'
> | S n' =>
> match (div2rem n) with
> | (x, O) => T (F (fst (div2rem (S n'))) (div2smaller n'))
> | (x, S y) => ST (F (fst (div2rem (S n'))) (div2smaller n'))
> end
> end)).
> Basically I define nat_to_bin n in terms of nat_to_bin (n/2)
> Here div2smaller n' is a proof that (S n')/2<S n' so that we can use
> strong_rec.
> Lemma div2smaller:
> forall n, fst (div2rem (S n))<S n.
> However this gives the error
> Error:
> In environment
> n : nat
> F : forall m : nat, m < n -> bin
> n' : nat
> x : nat
> n0 : nat
> The term "div2smaller n'" has type "fst (div2rem (S n')) < S n'"
> while it is expected to have type "fst (div2rem (S n')) < n".
> How can I tell Coq that n=S n'?
> For reference here is the definition for bin:
> Inductive bin : Type :=
> | O' : bin
> | T : bin -> bin (*twice*)
> | ST: bin -> bin. (*one more than twice*)
> Thanks,
> Holden
- [Coq-Club] How to obtain the statement "n = S n'" within a match?, Holden Lee, 02/08/2015
- Re: [Coq-Club] How to obtain the statement "n = S n'" within a match?, Cedric Auger, 02/08/2015
- Re: [Coq-Club] How to obtain the statement "n = S n'" within a match?, Jean-Francois Monin, 02/08/2015
- Re: [Coq-Club] How to obtain the statement "n = S n'" within a match?, Kristopher Micinski, 02/08/2015
