coq-club - RE: [Coq-Club] How to handle "invisible" evars created by eapply?
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] How to handle "invisible" evars created by eapply?
  • Date: Fri, 13 Feb 2015 16:36:28 +0000
  • Accept-language: de-DE, en-US
Dear Jonathan,
thanks, this helps! Maybe I am mixing up some things here, but I thought that for most evars I have seen so far, some hypothesis gave the type of the evar. In general I would like to have a way to match on all free evars (not only those occurring in the goal) and their type. Your Ltac script is easily extended to this, but I wonder how efficient it is, when applied repeatedly in some automation script.
Maybe it is better to avoid creation of evars in automation in the first place. I am experimenting a bit and see what works well and what results in problems.
Best regards,
Michael
From: coq-club-request AT inria.fr [mailto:coq-club-request AT inria.fr] On Behalf Of Jonathan Leivent
Sent: Friday, February 13, 2015 4:49 PM
To: coq-club AT inria.fr
Subject: Re: [Coq-Club] How to handle "invisible" evars created by eapply?
On 02/13/2015 09:44 AM, Soegtrop, Michael wrote:
Dear Coq users,
trying to write my own "Chlipala style" crush tactic, I came across the effect that eapply creates evars which don't have an existential hypothesis:
  Require Import Bool.
  Require Import Vector.
  Class BooleanEqualityT (T : Type) : Type :=
      eqb       : T -> T -> bool ;
      eqb_axiom : forall x y, reflect (x = y) (eqb x y)
  Instance BooleanEquality_vector {T : Type} {Beq : BooleanEqualityT T} (n : nat) : BooleanEqualityT (Vector.t T n).
    eapply Build_BooleanEqualityT.
Results in:
  1 subgoal
  T : Type
  n : nat
  ______________________________________(1/1)
  forall x y : t T n, reflect (x = y) (?eqb x y)
The strange thing is that the evar ?eqb doesn't appear as existential in the hypothesis. This makes it difficult to detect the evar in automation and to set it.
I am unclear as to what kind of appearance you were expecting.  For example, if you at this point do [set (eqb:=?eqb)], that will generate a local definition that will show up in the hypotheses:
1 subgoal
T : Type
n : nat
eqb := ?eqb : t T n -> t T n -> bool
forall x y : t T n, reflect (x = y) (eqb x y)
So the question is: how can I detect in automation that I have such an evar and get its type?
If you want a tactic that can detect occurrences of free evars in the conclusion and generate such local definition hypotheses from them, that is fairly easy to do:
  Ltac gen_evar_local_defs :=
      repeat match goal with |- context[?V] => is_evar V; set V end.
It is possible to do something like this for evars under binders as well.
Or, is there something else you want to occur?
-- Jonathan
