- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to handle "invisible" evars created by eapply?
- Date: Fri, 13 Feb 2015 13:08:38 -0500
On 02/13/2015 11:36 AM, Soegtrop, Michael wrote:
... Your Ltac script is easily extended to this, but I wonder how efficient
it is, when applied repeatedly in some automation script.
Sorry I forgot to respond to this: You can use "has_evar" to perhaps make the tactic more efficient by avoiding the context searches unless an evar is present (assuming that has_evar does the searches faster internally, of course). However, note that "has_evar" will succeed even when the only evars present are under binders - at which point context won't find them.
There is also a surprisingly simple but extremely kludgey way to determine if there are any evars anywhere in a goal without searching via has_evars or context - but again it will succeed even if the only evars are under bindiers. It relies on the fact that the abstract tactic fails if there are any evars present:
Ltac has_evars_somewhere := try abstract fail 1 "no evars present".
I haven't measured the performance of this relative to using has_evars on every hypothesis and the conclusion. I also suspect that several Coq developers might have become nauseous by seeing that tactic ;)
-- Jonathan
- [Coq-Club] How to handle "invisible" evars created by eapply?, Soegtrop, Michael, 02/13/2015
- Re: [Coq-Club] How to handle "invisible" evars created by eapply?, Jonathan Leivent, 02/13/2015
- RE: [Coq-Club] How to handle "invisible" evars created by eapply?, Soegtrop, Michael, 02/13/2015
- Re: [Coq-Club] How to handle "invisible" evars created by eapply?, Matthieu Sozeau, 02/14/2015
- RE: [Coq-Club] How to handle "invisible" evars created by eapply?, Soegtrop, Michael, 02/18/2015
