- From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] How to handle "invisible" evars created by eapply?
- Date: Wed, 18 Feb 2015 11:43:36 +0000
- Accept-language: de-DE, en-US
Dear Jonathan, Matthieu,
thanks a lot for your hints! I am experimenting with different ways of doing
proof automation and see what works best. For the top down approach I want to
prune the search tree for specific types of evars. I know that if I can't
instantiate evars of specific types now, I won't be able to do so later, so I
can discard the current search path right away. The proof automation works
fine without this, but if the proofs get larger, this might reduce search
time considerably. But of cause it won't improve performance if a frequent
search for evars of specific types takes more time than I save by pruning the
tree.
Best regards,
Michael
-----Original Message-----
coq-club-request AT inria.fr
[mailto:coq-club-request AT inria.fr]
On Behalf Of Jonathan Leivent
Sent: Friday, February 13, 2015 7:09 PM
To:
Subject: Re: [Coq-Club] How to handle "invisible" evars created by eapply?
On 02/13/2015 11:36 AM, Soegtrop, Michael wrote:
> ... Your Ltac script is easily extended to this, but I wonder how efficient
> it is, when applied repeatedly in some automation script.
Sorry I forgot to respond to this: You can use "has_evar" to perhaps make
the tactic more efficient by avoiding the context searches unless an evar is
present (assuming that has_evar does the searches faster internally, of
course). However, note that "has_evar" will succeed even when the only evars
present are under binders - at which point context won't find them.
There is also a surprisingly simple but extremely kludgey way to determine if
there are any evars anywhere in a goal without searching via has_evars or
context - but again it will succeed even if the only evars are under
bindiers. It relies on the fact that the abstract tactic fails if there are
any evars present:
Ltac has_evars_somewhere := try abstract fail 1 "no evars present".
I haven't measured the performance of this relative to using has_evars on
every hypothesis and the conclusion. I also suspect that several Coq
developers might have become nauseous by seeing that tactic ;)
-- Jonathan
- [Coq-Club] How to handle "invisible" evars created by eapply?, Soegtrop, Michael, 02/13/2015
- Re: [Coq-Club] How to handle "invisible" evars created by eapply?, Jonathan Leivent, 02/13/2015
- RE: [Coq-Club] How to handle "invisible" evars created by eapply?, Soegtrop, Michael, 02/13/2015
- Re: [Coq-Club] How to handle "invisible" evars created by eapply?, Matthieu Sozeau, 02/14/2015
- RE: [Coq-Club] How to handle "invisible" evars created by eapply?, Soegtrop, Michael, 02/18/2015
