- From: Frédéric Besson <frederic.besson AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Newbie question on cyclic set proofs
- Date: Fri, 20 Feb 2015 20:36:29 +0100
Hi,
> On 20 févr. 2015, at 19:09, George Van Treeck
> <treeck AT yahoo.com>
> wrote:
> Given a definition and lemma like:
> Definition cyclic_successor (m setsize: nat) : nat :=
> if beq_nat m setsize then 1 else S m.
> Lemma cyclic_successor_induction1 : forall m setsize: nat,
> 1 <= m < setsize -> cyclic_successor m setsize = S m.
> Clearly « beq_nat m setsize" always fails where "m < setsize".
There should be in the library theorem linking the boolean equality test
beq_nat : nat -> nat -> bool with the equality predicate =.
After doing a case analysis over the condition, the proof should be purely
arithmetic.
> So, the proof should be trivial. But, when I attempt to use induction it
> creates new goals with larger successors because the definition is not
> inductive with a decreasing term. Which rewrite tactics that can be used
> here to equate the two conditions?
> -George
- [Coq-Club] Newbie question on cyclic set proofs, George Van Treeck, 02/20/2015
- Re: [Coq-Club] Newbie question on cyclic set proofs, Frédéric Besson, 02/20/2015
- Re: [Coq-Club] Newbie question on cyclic set proofs, George Van Treeck, 02/22/2015
