- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Newbie question on cyclic set proofs
- Date: Fri, 20 Feb 2015 18:09:57 +0000 (UTC)
Given a definition and lemma like:
Definition cyclic_successor (m setsize: nat) : nat :=
if beq_nat m setsize then 1 else S m.
Lemma cyclic_successor_induction1 : forall m setsize: nat,
1 <= m < setsize -> cyclic_successor m setsize = S m.
Clearly "beq_nat m setsize" always fails where "m < setsize". So, the proof should be trivial. But, when I attempt to use induction it creates new goals with larger successors because the definition is not inductive with a decreasing term. Which rewrite tactics that can be used here to equate the two conditions?
-George
- [Coq-Club] Newbie question on cyclic set proofs, George Van Treeck, 02/20/2015
- Re: [Coq-Club] Newbie question on cyclic set proofs, Frédéric Besson, 02/20/2015
- Re: [Coq-Club] Newbie question on cyclic set proofs, George Van Treeck, 02/22/2015
