- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Newbie question on cyclic set proofs
- Date: Sun, 22 Feb 2015 02:35:35 +0000 (UTC)
Unfortunately, case analysis does not work because both variables are uninstantiated and the cyclic_successor definition is not inductive. Using the destruct/reflexivity tactics for case analysis requires an infinite number of proof steps (generates the same subgoals as the induction/reflexivity tactics).
But, your suggestion of there being link of beq_nat to eq gave me an idea of equating less than to not beq_nat, which eliminates the need for case analysis. In case someone else might find it useful:
Lemma lt_beq_false : forall m n: nat,
m < n -> beq_nat m n = false.
Proof.
intros.
apply beq_nat_false_iff.
auto with *.
Qed.
Definition cyclic_successor (m setsize: nat) : nat :=
if beq_nat m setsize then 1 else S m.
Lemma cyclic_successor_induction1 : forall m setsize: nat,
m < setsize -> cyclic_successor m setsize = S m.
Proof.
intros.
unfold cyclic_successor.
apply lt_beq_false in H.
rewrite -> H.
trivial.
Qed.
Thank you for the suggestion.
-George
On Friday, February 20, 2015 11:36 AM, Frédéric Besson <frederic.besson AT inria.fr> wrote:
Hi,
> On 20 févr. 2015, at 19:09, George Van Treeck <treeck AT yahoo.com> wrote:
> Given a definition and lemma like:
> 1 <= m < setsize -> cyclic_successor m setsize = S m.
> Clearly « beq_nat m setsize" always fails where "m < setsize".
There should be in the library theorem linking the boolean equality test beq_nat : nat -> nat -> bool with the equality predicate =.
After doing a case analysis over the condition, the proof should be purely arithmetic.
> So, the proof should be trivial. But, when I attempt to use induction it creates new goals with larger successors because the definition is not inductive with a decreasing term. Which rewrite tactics that can be used here to equate the two conditions?
> -George
> -George
- [Coq-Club] Newbie question on cyclic set proofs, George Van Treeck, 02/20/2015
- Re: [Coq-Club] Newbie question on cyclic set proofs, Frédéric Besson, 02/20/2015
- Re: [Coq-Club] Newbie question on cyclic set proofs, George Van Treeck, 02/22/2015
