- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] difference between coqchk and Print Assumptions
- Date: Sun, 29 Mar 2015 13:27:25 -0400
Even worse - a file that just says:
Require Import EquivDec.
when run through coqchk -o will produce:
* Axioms:
Coq.Logic.ProofIrrelevance.proof_irrelevance
Coq.Logic.FunctionalExtensionality.functional_extensionality_dep
Coq.Logic.JMeq.JMeq_eq
Coq.Logic.Eqdep.Eq_rect_eq.eq_rect_eq
How can it depend on those axioms when it doesn't contain a single definition?
-- Jonathan
On 03/29/2015 01:02 PM, Jonathan Leivent wrote:
I have a .v file that has as its only contents:
Require Export EquivDec.
Class Ordered(A : Set) :=
eq_dec :> EqDec A eq;
lt : A -> A -> Prop;
lt_strict :> StrictOrder lt;
compare : A -> A -> comparison;
compare_spec : forall x y, CompareSpecT (eq x y) (lt x y) (lt y x) (compare x y)
Print Assumptions Ordered.
The last Print Assumptions outputs "Closed under the global context".
When I run that file through coqchk with the -o option, it prints this at the end:
* Axioms:
Why is coqchk seeing those axioms when Print Assumptions isn't? The difference isn't due to the use of "Export" - as I tried "Import" instead with the same results.
-- Jonathan
- [Coq-Club] difference between coqchk and Print Assumptions, Jonathan Leivent, 03/29/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Jonathan Leivent, 03/29/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Enrico Tassi, 03/29/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Arnaud Spiwack, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Pierre Courtieu, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Enrico Tassi, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Pierre-Marie Pédrot, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Jonathan Leivent, 03/30/2015
