- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] difference between coqchk and Print Assumptions
- Date: Mon, 30 Mar 2015 13:33:44 +0200
Indeed the -o option here is not precise enough.
would it make sense to submitting a feature wish for some [coqchk
-print-assumptions-for foo] option?
P.
2015-03-30 11:04 GMT+02:00 Arnaud Spiwack
<aspiwack AT lix.polytechnique.fr>:
> If you have a better behaviour to suggest for `coqchk` please do. But I'm
> not sure it will be easy, unfortunately.
> On 29 March 2015 at 19:54, Jonathan Leivent
> <jonikelee AT gmail.com>
> wrote:
>> On 03/29/2015 01:41 PM, Enrico Tassi wrote:
>>> On Sun, Mar 29, 2015 at 01:27:25PM -0400, Jonathan Leivent wrote:
>>>> Even worse - a file that just says:
>>>> Require Import EquivDec.
>>>> when run through coqchk -o will produce:
>>> Coqchk prints all the axioms, as in "Axiom" keyword, loaded in the
>>> environment. "Print Assumptions name" prints only the ones used by
>>> name.
>>> Best,
>> Right - I should have inferred that. Although that coqchk -o behavior
>> seems not too useful, in that case.
>> -- Jonathan
- [Coq-Club] difference between coqchk and Print Assumptions, Jonathan Leivent, 03/29/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Jonathan Leivent, 03/29/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Enrico Tassi, 03/29/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Arnaud Spiwack, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Pierre Courtieu, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Enrico Tassi, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Pierre-Marie Pédrot, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Jonathan Leivent, 03/30/2015
