- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] difference between coqchk and Print Assumptions
- Date: Mon, 30 Mar 2015 11:04:08 +0200
If you have a better behaviour to suggest for `coqchk` please do. But I'm not sure it will be easy, unfortunately.
On 29 March 2015 at 19:54, Jonathan Leivent <jonikelee AT gmail.com> wrote:
Right - I should have inferred that. Although that coqchk -o behavior seems not too useful, in that case.
On 03/29/2015 01:41 PM, Enrico Tassi wrote:
On Sun, Mar 29, 2015 at 01:27:25PM -0400, Jonathan Leivent wrote:
Even worse - a file that just says:Coqchk prints all the axioms, as in "Axiom" keyword, loaded in the
Require Import EquivDec.
when run through coqchk -o will produce:
environment. "Print Assumptions name" prints only the ones used by
name.
Best,
-- Jonathan
- [Coq-Club] difference between coqchk and Print Assumptions, Jonathan Leivent, 03/29/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Jonathan Leivent, 03/29/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Enrico Tassi, 03/29/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Arnaud Spiwack, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Pierre Courtieu, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Enrico Tassi, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Pierre-Marie Pédrot, 03/30/2015
- Re: [Coq-Club] difference between coqchk and Print Assumptions, Jonathan Leivent, 03/30/2015
