- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] 8.5 and MathClasses
- Date: Thu, 07 May 2015 00:09:34 +0000
Have a partition that is case sensitive... Although those ambiguities could be dealt with in a better way using qualification IIRC
Le mer. 6 mai 2015 à 20:43, Vadim Zaliva <vzaliva AT cmu.edu> a écrit :
On May 6, 2015, at 10:14 , Jason Gross <jasongross9 AT gmail.com> wrote:It seems to be available on opam: https://github.com/coq/repo-unstable/blob/master/packages/coq:contrib:math-classes/coq:contrib:math-classes.dev/opamThanks! That leads me to OPAM/Coq question. I am already using OPAM for OCaml stuff on my Mac. However it would not work for MathClasses since they require case-sensitive file system which is not default on Macs. I usually create and mount disk image with case-sensitive file system just for MathClasses. I would like very much to use OPAM for Coq packages, but at least for this one case-sensitivity would be a problem. How people are dealing with this?Sincerely,
Vadim Zaliva--CMU ECE PhD candidateMobile: +1(510)220-1060Skype: vzaliva
- [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/06/2015
- Re: [Coq-Club] 8.5 and MathClasses, Jason Gross, 05/06/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/06/2015
- Re: [Coq-Club] 8.5 and MathClasses, Matthieu Sozeau, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Bas Spitters, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Guillaume Claret, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/11/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/12/2015
- Re: [Coq-Club] 8.5 and MathClasses, Matthieu Sozeau, 05/12/2015
- Re: [Coq-Club] 8.5 and MathClasses, Bas Spitters, 05/29/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/29/2015
- Re: [Coq-Club] 8.5 and MathClasses, Jason Gross, 05/07/2015
