- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] 8.5 and MathClasses
- Date: Mon, 11 May 2015 09:21:18 -0700
Yes,
The patch from Jason does just that and solves the problem with MathClasses.
Vadim
> On May 7, 2015, at 11:51 , Guillaume Claret
> <guillaume AT claret.me>
> wrote:
> Does it work if you replace the `Require Import` with:
> Require Import
> Coq.Lists.List SetoidList implementations.list
> abstract_algebra interfaces.finite_sets interfaces.orders
> theory.lattices orders.lattices.
> I mean, all the imports should be fully prefixed to avoid a maximum of
> ambiguities.
> Best,
> Guillaume
> The 05/07/2015 19:46, Vadim Zaliva wrote:
>>> On May 7, 2015, at 4:33 , Bas Spitters
>>> <b.a.w.spitters AT gmail.com
>>> <mailto:b.a.w.spitters AT gmail.com>>
>>> wrote:
>>> I haven't thought deeply about case sensitivity, but if it requires a
>>> minor change, I'd be willing to accept a pull request.
>> Case-sensitivity problem is very annoying on MacOS. Here is a
>> background: default MacOS file system is case-insensitive
>> but case-preserving. So you you create file “A” it will be shown in
>> upper case but you can open it either as “a” or “A”. Here is
>> what happens with MathClasses:
>> $ coqc -verbose -R . MathClasses -q implementations/list_finite_set.v
>> Require Import
>> Warning: List.vo has been found in
>> [ /Users/lord/tmp/math-classes/implementations ;
>> /Volumes/CoqLibs/coq/lib/coq/theories/Lists ];
>> loading /Users/lord/tmp/math-classes/implementations/List.vo
>> File "./implementations/list_finite_set.v", line 1, characters 0-148:
>> Error: The file /Users/lord/tmp/math-classes/implementations/List.vo
>> contains library
>> MathClasses.implementations.list and not library
>> MathClasses.implementations.List
>> I think it is not really MathClasses problem. It could occur whenever
>> you import some module of which you have several
>> versions in your search path with names in different case.
>> I think the proper solution is for coq to ignore files where file name
>> does not match enclosed implementation, perhaps issuing a warning
>> instead of an error. This should be a trivial patch to Coq itself. Maybe
>> right now before 8.5 release it is a good way to put it in? MacOS users
>> will benefit from it.
>> Sincerely,
>> Vadim Zaliva
>> CMU ECE PhD candidate
>> Mobile: +1(510)220-1060
>> Skype: vzaliva
Sincerely,
Vadim Zaliva
Skype: vzaliva
- [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/06/2015
- Re: [Coq-Club] 8.5 and MathClasses, Jason Gross, 05/06/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/06/2015
- Re: [Coq-Club] 8.5 and MathClasses, Matthieu Sozeau, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Bas Spitters, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Guillaume Claret, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/11/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/12/2015
- Re: [Coq-Club] 8.5 and MathClasses, Matthieu Sozeau, 05/12/2015
- Re: [Coq-Club] 8.5 and MathClasses, Bas Spitters, 05/29/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/29/2015
- Re: [Coq-Club] 8.5 and MathClasses, Jason Gross, 05/07/2015
- Message not available
- Re: [Coq-Club] 8.5 and MathClasses, Cedric Auger, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Pierre Boutillier, 05/08/2015
