- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] 8.5 and MathClasses
- Date: Thu, 07 May 2015 20:51:15 +0200
Does it work if you replace the `Require Import` with:
Require Import
Coq.Lists.List SetoidList implementations.list
abstract_algebra interfaces.finite_sets interfaces.orders
theory.lattices orders.lattices.
I mean, all the imports should be fully prefixed to avoid a maximum of ambiguities.
Best,
Guillaume
The 05/07/2015 19:46, Vadim Zaliva wrote:
On May 7, 2015, at 4:33 , Bas Spitters
<b.a.w.spitters AT gmail.com
<mailto:b.a.w.spitters AT gmail.com>>
wrote:
I haven't thought deeply about case sensitivity, but if it requires a
minor change, I'd be willing to accept a pull request.
Case-sensitivity problem is very annoying on MacOS. Here is a
background: default MacOS file system is case-insensitive
but case-preserving. So you you create file “A” it will be shown in
upper case but you can open it either as “a” or “A”. Here is
what happens with MathClasses:
$ coqc -verbose -R . MathClasses -q implementations/list_finite_set.v
Require Import
Warning: List.vo has been found in
[ /Users/lord/tmp/math-classes/implementations ;
/Volumes/CoqLibs/coq/lib/coq/theories/Lists ];
loading /Users/lord/tmp/math-classes/implementations/List.vo
File "./implementations/list_finite_set.v", line 1, characters 0-148:
Error: The file /Users/lord/tmp/math-classes/implementations/List.vo
contains library
MathClasses.implementations.list and not library
MathClasses.implementations.List
I think it is not really MathClasses problem. It could occur whenever
you import some module of which you have several
versions in your search path with names in different case.
I think the proper solution is for coq to ignore files where file name
does not match enclosed implementation, perhaps issuing a warning
instead of an error. This should be a trivial patch to Coq itself. Maybe
right now before 8.5 release it is a good way to put it in? MacOS users
will benefit from it.
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
- [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/06/2015
- Re: [Coq-Club] 8.5 and MathClasses, Jason Gross, 05/06/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/06/2015
- Re: [Coq-Club] 8.5 and MathClasses, Matthieu Sozeau, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Bas Spitters, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Guillaume Claret, 05/07/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/11/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/12/2015
- Re: [Coq-Club] 8.5 and MathClasses, Matthieu Sozeau, 05/12/2015
- Re: [Coq-Club] 8.5 and MathClasses, Bas Spitters, 05/29/2015
- Re: [Coq-Club] 8.5 and MathClasses, Vadim Zaliva, 05/29/2015
- Re: [Coq-Club] 8.5 and MathClasses, Jason Gross, 05/07/2015
- Message not available
- Re: [Coq-Club] 8.5 and MathClasses, Cedric Auger, 05/07/2015
