- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Basic Exercises
- Date: Fri, 15 May 2015 17:35:12 +0200
Hi,
You can define bin_to_nat. You should use div instead of divide. div : nat -> nat -> nat is the division function (what you want) while divide : nat -> nat -> Prop is the divisibility predicate. i.e., "divide a b” is the logical statement “a is divisible by b”.
Take a look at the documentation of “Coq.Numbers.Natural.Peano.NPeano” at https://coq.inria.fr/library/Coq.Numbers.Natural.Peano.NPeano.html for more details.
Regards,
Amin
On 15 May 2015, at 17:20, Kenneth Adam Miller <kennethadammiller AT gmail.com> wrote:So, I'm doing the basic exercises, and I encountered this issue:Inductive bin : Type :=| O : bin| Beven : bin -> bin| Bodd : bin -> bin.Fixpoint incr (b : bin) :=match b with| O => Bodd b| Beven e => Bodd (Beven e)| Bodd o => Beven (Bodd o)end.Require Import Coq.Numbers.Natural.Peano.NPeano.Fixpoint bin_to_nat (b : bin) : nat :=match b with| O => 0| Beven e => 2 * (( divide (bin_to_nat e) 2) + 1)| Bodd o => 1 + (bin_to_nat o)end.(* Error:Toplevel input, characters 91-114:Error: In environmentbin_to_nat : bin -> natb : bine : binThe term "(bin_to_nat e | 2)" has type "Prop"while it is expected to have type "nat".*)Why can't I define bin_to_nat to be recursive just as I would in OCaml?
- [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Amin Timany, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Tahina Ramananandro, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Dan Christensen, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Cedric Auger, 05/18/2015
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/18/2015
- Re: [Coq-Club] Basic Exercises, Dan Christensen, 05/16/2015
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/17/2015
- Re: [Coq-Club] Basic Exercises, Dan Christensen, 05/17/2015
