- From: Kenneth Adam Miller <kennethadammiller AT gmail.com>
- To: coq-club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Basic Exercises
- Date: Sat, 16 May 2015 18:05:32 -0400
It appeared correct to me, I did what it requested for that exercise. It said something along the lines of: an incr and bin to Nat call could correspond to a final value equal to direct Nat incrementation. Test it with incrementing from 1 to 5.
It passed for all those, 1 to 5. Is what I've done poor for lack of correctness or that it produces inefficient code?
(At the current moment I'm not by the computer where I did this work, so I can look at editing it, only interaction)
On May 16, 2015 10:32 AM, "Dan Christensen" <jdc AT uwo.ca> wrote:
[I originally sent this yesterday, but it got stuck in moderation
because I wasn't yet subscribed to the list, so I'm resending.]
Kenneth Adam Miller <kennethadammiller AT gmail.com> writes:
> So, I'm doing the basic exercises, and I encountered this issue:
It looks like you are attempting the exercise on binary numbers
from near the end of:
http://www.cis.upenn.edu/~bcpierce/sf/current/Basics.html
http://www.cis.upenn.edu/~bcpierce/sf/current/Basics.v
> Inductive bin : Type :=
> | O : bin
> | Beven : bin -> bin
> | Bodd : bin -> bin.
In this representation of binary numbers, a term like
Beven Bodd Bodd O
would correspond to the binary number 110.
> Fixpoint incr (b : bin) :=
> match b with
> | O => Bodd b
> | Beven e => Bodd (Beven e)
> | Bodd o => Beven (Bodd o)
> end.
If this is supposed to add one to a binary number, it isn't doing the
right thing. The number of bits should only sometimes increase.
> Require Import Coq.Numbers.Natural.Peano.NPeano.
> Fixpoint bin_to_nat (b : bin) : nat :=
> match b with
> | O => 0
> | Beven e => 2 * (( divide (bin_to_nat e) 2) + 1)
> | Bodd o => 1 + (bin_to_nat o)
> end.
[As others have said] "divide x y" is the proposition that x divides
evenly into y.
But a correct solution here shouldn't use division at all.
Dan
- [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Amin Timany, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Tahina Ramananandro, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Dan Christensen, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Cedric Auger, 05/18/2015
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/18/2015
- Re: [Coq-Club] Basic Exercises, Dan Christensen, 05/16/2015
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/17/2015
- Re: [Coq-Club] Basic Exercises, Dan Christensen, 05/17/2015
- Message not available
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/22/2015
