- From: Kenneth Adam Miller <kennethadammiller AT gmail.com>
- To: coq-club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Basic Exercises
- Date: Fri, 15 May 2015 11:53:52 -0400
Thank you so so much :)
On Fri, May 15, 2015 at 11:39 AM, Tahina Ramananandro <ramananandro AT reservoir.com> wrote:
Sorry for the duplicate. Thanks Amin for pointing to the documentation.--TahinaOn Fri, May 15, 2015 at 11:37 AM, Tahina Ramananandro <ramananandro AT reservoir.com> wrote:(coq 8.4)In fact, you can, the problem is not in the recursive definition, but in your use of `divide'. In your case, you should use `div' instead. If you look at their definitions and types:Print divide.Print div.you'll see that (divide a b) corresponds to the predicate "a divides b", whereas (div a b) is the number (a / b) that you need here.Hope it helps,--Tahina--On Fri, May 15, 2015 at 11:20 AM, Kenneth Adam Miller <kennethadammiller AT gmail.com> wrote:So, I'm doing the basic exercises, and I encountered this issue:Inductive bin : Type :=| O : bin| Beven : bin -> bin| Bodd : bin -> bin.Fixpoint incr (b : bin) :=match b with| O => Bodd b| Beven e => Bodd (Beven e)| Bodd o => Beven (Bodd o)end.Require Import Coq.Numbers.Natural.Peano.NPeano.Fixpoint bin_to_nat (b : bin) : nat :=match b with| O => 0| Beven e => 2 * (( divide (bin_to_nat e) 2) + 1)| Bodd o => 1 + (bin_to_nat o)end.(* Error:Toplevel input, characters 91-114:Error: In environmentbin_to_nat : bin -> natb : bine : binThe term "(bin_to_nat e | 2)" has type "Prop"while it is expected to have type "nat".*)Why can't I define bin_to_nat to be recursive just as I would in OCaml?Tahina Oliver Ramananandro, Ph. D.Senior Engineer, Advanced Compilers and Formal VerificationReservoir Labs, Inc.632 Broadway, Suite 803New York, NY 10012USAPhone: +1 (212) 780-0527 ext. 157--Tahina Oliver Ramananandro, Ph. D.Senior Engineer, Advanced Compilers and Formal VerificationReservoir Labs, Inc.632 Broadway, Suite 803New York, NY 10012USAPhone: +1 (212) 780-0527 ext. 157
- [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Amin Timany, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Tahina Ramananandro, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Dan Christensen, 05/15/2015
- Re: [Coq-Club] Basic Exercises, Cedric Auger, 05/18/2015
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/18/2015
- Re: [Coq-Club] Basic Exercises, Dan Christensen, 05/16/2015
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/17/2015
- Re: [Coq-Club] Basic Exercises, Dan Christensen, 05/17/2015
- Message not available
- Re: [Coq-Club] Basic Exercises, Kenneth Adam Miller, 05/22/2015
