- To: coq-club AT inria.fr
- Subject: [Coq-Club] proofs involving 'match' constructs
- Date: Fri, 29 May 2015 11:21:49 -0700
I am wondering what is a good approach to trying to prove some things like
this:
Require Import Vector.
Require Import ArithRing.
Program Fixpoint ScatHUnion_0 {A} {n:nat} (pad:nat): t A n -> t (option A)
((S pad)*n) :=
match n return (t A n) -> (t (option A) ((S pad)*n)) with
| 0 => fun _ => @nil (option A)
| S p => fun a => cons _ (Some (hd a)) _ (append (const None pad)
(ScatHUnion_0 pad (tl a)))
end.
Next Obligation.
ring.
Defined.
(This definition works only under Coq 8.5. Under 8.4 I had to define it
differently).
I stuck proving the following trivial lemma:
Lemma test0: @ScatHUnion_0 nat 0 0 (@nil nat) = (@nil (option nat)).
I could not get much further than:
test0 < compute.
1 subgoal
match mult_n_O 0 in (_ = y) return (t (option nat) y) with
| eq_refl => nil (option nat)
end = nil (option nat)
Any suggestions how to deal with proving constructs like this?
Thanks!
Sincerely,
Vadim Zaliva
CMU ECE PhD candidate
Mobile: +1(510)220-1060
Skype: vzaliva
- [Coq-Club] proofs involving 'match' constructs, Vadim Zaliva, 05/29/2015
- Re: [Coq-Club] proofs involving 'match' constructs, Amin, 05/29/2015
- Re: [Coq-Club] proofs involving 'match' constructs, Jason Gross, 05/29/2015
- Re: [Coq-Club] proofs involving 'match' constructs, Laurent Théry, 05/29/2015
