coq-club - [Coq-Club] Interaction between ; (tactic sequence) and shelving
  • From: Armaël Guéneau <armael.gueneau AT ens-lyon.fr>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Interaction between ; (tactic sequence) and shelving
  • Date: Fri, 19 Jun 2015 17:47:51 +0200
Hi,
I'm encountering a strange behavior that I can't really explain to
myself, and that seems to boil down to the interaction between the
tactic sequence (";") and tactics producing shelved goals like
eauto/eapply.
I have a Ltac tactic of the form:
Ltac tac :=
eapply foo;
apply bar.
(n.b.: [eapply foo] produces only one goal)
In some context, tac was failing for an unknown reason, so I inlined
it and started investigating. In this proof context, [foo] needs an
implicit argument that cannot be found directly in the context, so
eapply decides to produce the corresponding goal as a shelved goal.
So, in this context, just using [eapply foo.] succeeds, and produces a
shelved goal [H: P]. After that, I can use [apply bar.] successfully.
However, in the same proof context, [eapply foo; apply bar.] fails.
The error message is "Unable to satisfy the following constraints:
?H: P" (so, the same goal that was previously shelved).
Soooo, I don't really understand why this happens. Do you know how I
should write my [tac] tactic for it to work just as a
[eapply foo. apply bar.]?
(oh, and I'm running Coq 8.5beta2)
-- Armaël
