- From: Armaël Guéneau <armael.gueneau AT ens-lyon.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Interaction between ; (tactic sequence) and shelving
- Date: Tue, 23 Jun 2015 16:32:35 +0200
On 06/19/2015 07:49 PM, Jonathan Leivent wrote: > Do you have a test case? I tried a few simple cases, and couldn't replicate the behavior. Sure. Actually, I didn't have a simple one at first; now I have something. Minimizing the thing was not as simple as I expected, as I couldn't understand clearly when some subgoal was going to be shelved. The behavior I observed seems to appear on implicit parameters specified using Context in a section. So, anyway, here's a test case (maybe not minimal). Definition filter (A: Type) := (A -> Prop) -> Prop. Class Filter {A: Type} (f: filter A) := { filter_foo : False }. Section S. Context {A: Type} {f: filter A} `{@Filter A f}. Lemma filter_universe: forall P : A -> Prop, (forall a, P a) -> f P. Proof. admit. Admitted. End S. Axiom f : filter unit. Axiom P : Prop. Axiom p : P. Goal f (fun _ => P). (* Succeeds. *) eapply filter_universe; intros. apply p. (* Fails. *) eapply filter_universe; intros; apply p. (Of course here, the goal is not solved by the first line, but the application of tactics succeeds, leaving a shelved goal to be proved; using the second line instead of the first fails.) |
- [Coq-Club] Interaction between ; (tactic sequence) and shelving, Armaël Guéneau, 06/19/2015
- Re: [Coq-Club] Interaction between ; (tactic sequence) and shelving, Jonathan Leivent, 06/19/2015
- Re: [Coq-Club] Interaction between ; (tactic sequence) and shelving, Armaël Guéneau, 06/23/2015
- Re: [Coq-Club] Interaction between ; (tactic sequence) and shelving, Jonathan Leivent, 06/23/2015
- Re: [Coq-Club] Interaction between ; (tactic sequence) and shelving, Armaël Guéneau, 06/24/2015
