- From: Armaël Guéneau <armael.gueneau AT ens-lyon.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Interaction between ; (tactic sequence) and shelving
- Date: Wed, 24 Jun 2015 15:31:56 +0200
On 06/23/2015 05:20 PM, Jonathan Leivent wrote:
> This is indeed quite strange. I tried inserting an "instantiate" in> that failing sequence, but that didn't help. Also, if the failing > sequence is modified to be "eapply filter_universe; [|intros; apply > p]", it fails saying that it expects just 1 tactic (meaning it has > just one subgoal) - so, the failure is not due to "apply p" being > applied to two subgoals. I also printed out the goal using a > debugging tactic just prior to the final failing "apply p", and it > is "a : unit |- P" just as expected. > > Furthermore, replacing that final "apply p" with "exact p", "eapply > p" or "refine p" makes the sequence work. It also works to first > pose p, then use "assumption" in place of that final "apply p". > > Also, adding "Axiom g : Filter f" to the list of axioms makes the > final "apply p" work - evidently because then the "eapply > filter_universe" doesn't need to shelve the typeclass constriant "|- > Filter f". > > I think this is probably a bug about something specific to apply > vs. typeclass constraints. It is as if apply alone among the > tactics believes it must solve typeclass constraints shelved earlier > in the sequence. >
Thanks for the investigation! I guess I should report the bug, then...
Thanks!
- [Coq-Club] Interaction between ; (tactic sequence) and shelving, Armaël Guéneau, 06/19/2015
- Re: [Coq-Club] Interaction between ; (tactic sequence) and shelving, Jonathan Leivent, 06/19/2015
- Re: [Coq-Club] Interaction between ; (tactic sequence) and shelving, Armaël Guéneau, 06/23/2015
- Re: [Coq-Club] Interaction between ; (tactic sequence) and shelving, Jonathan Leivent, 06/23/2015
- Re: [Coq-Club] Interaction between ; (tactic sequence) and shelving, Armaël Guéneau, 06/24/2015
