coq-club - Re: [Coq-Club] Unknown type error
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Unknown type error
  • Date: Mon, 29 Jun 2015 11:02:42 -0400
On 06/29/2015 10:43 AM, Pierre Courtieu wrote:
Quick answer (very common question). Try replaying the error after setting
this: "Set Printing All."
This will disable the hiding of implicit arguments and notations that make
you believe these two types are the same.
Best regards,
Pierre
Is there also a very common corresponding enhancement request: why not have Coq determine whether the two types will be visibly different when printed under the current settings - and if not, temporarily Set Printing All (and say that it is doing so to avoid confusion) in order to display a more meaningful error message - perhaps after first printing the type under current settings so that the user would have an easier time following the correspondence?
-- Jonathan
2015-06-29 16:31 GMT+02:00 Marcus Ramos
<marcus.ramos AT univasf.edu.br>:
Hi,
What should I do when I get the following error message?
"The term "H29" has type "In (inl n) (map inl r')"
while it is expected to have type "In (inl n) (map inl r')"."
I am using Coq 8.4 pl14 in CoqIDE for Windows 8.
Thanks in advance,
Marcus.
