- From: Yann Régis-Gianas <yrg AT pps.univ-paris-diderot.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Unknown type error
- Date: Mon, 29 Jun 2015 15:12:07 +0000
This has been implemented in the trunk by Pierre-Marie Pédrot.
➜ coq git:(trunk) ✗ coqtop
Welcome to Coq pangolin:/home/yann/git/research/coq,trunk (851539eca5016da98253308749131abae3ec7b93)
Coq < Parameter t : forall { n : nat }, Type.
t is assumed
Coq < Axiom a : t (n := 0).
a is assumed
Coq < Axiom b : t (n := 1).
b is assumed
Coq < Goal a = b.
Toplevel input, characters 9-10:
> Goal a = b.
Error: The term "b" has type "@t 1" while it is expected to have type "@t 0".
Le lun. 29 juin 2015 à 17:05, Pierre Courtieu <pierre.courtieu AT gmail.com> a écrit :
That would be great.P.2015-06-29 17:02 GMT+02:00 Jonathan Leivent <jonikelee AT gmail.com>:
On 06/29/2015 10:43 AM, Pierre Courtieu wrote:
Quick answer (very common question). Try replaying the error after setting
this: "Set Printing All."
This will disable the hiding of implicit arguments and notations that make
you believe these two types are the same.
Best regards,
Pierre
Is there also a very common corresponding enhancement request: why not have Coq determine whether the two types will be visibly different when printed under the current settings - and if not, temporarily Set Printing All (and say that it is doing so to avoid confusion) in order to display a more meaningful error message - perhaps after first printing the type under current settings so that the user would have an easier time following the correspondence?
-- Jonathan
2015-06-29 16:31 GMT+02:00 Marcus Ramos <marcus.ramos AT univasf.edu.br>:
Hi,
What should I do when I get the following error message?
"The term "H29" has type "In (inl n) (map inl r')"
while it is expected to have type "In (inl n) (map inl r')"."
I am using Coq 8.4 pl14 in CoqIDE for Windows 8.
Thanks in advance,
Marcus.
- [Coq-Club] Unknown type error, Marcus Ramos, 06/29/2015
- Re: [Coq-Club] Unknown type error, Pierre Courtieu, 06/29/2015
- Re: [Coq-Club] Unknown type error, Jonathan Leivent, 06/29/2015
- Re: [Coq-Club] Unknown type error, Yann Régis-Gianas, 06/29/2015
- Re: [Coq-Club] Unknown type error, Marcus Ramos, 06/29/2015
